Question about Onkyo TX-SR304 Receiver
I have "Onkyo TX-SR304E" and PS3. Will this rcvr support PS3 in all means? Is there any special setting hat I ned to follow to get the best from my rcvr as well as PS3? Pls advise. Your help much appreciated.
  • thiag_selvar Mar 06, 2009
    Thanks a lo that really helped..
    Problem Solver:
  • 13 Answers
What u can utilize on your tx-sr304 is the optical input at the back of the receiver. connect an optical cable from your PS3 into the receiver then follow these steps:
*make sure that the digital input on the front panel of your receiver matches where you placed the optical at the back of the tx-sr304 (either OPT1 or OPT2)
*all you have to do is keep pressing the digital input at the front panel until it goes to OPT1 or OPT2 (preferrably stay on DVD mode)
AFTER completing this go to your PS3 settings:
go to settings / then go to sound settings / then audio output settings / then set it to DIGITAL OUT (optical)/ then play and enjoy.....ü
Posted on Mar 05, 2009
I have Onkyo TX-SR304E receiver, it plays find on low volume, however when it is on 40 or above after some time the unit shuts off? How can I fix this problem? Regan
Check the impedance of your speakers. It sounds like the amp is getting overloaded and shutting down either for over current or over heating.
Most common issue is a partially blown speaker or crossover.
Sometimes it's just a rogue strand of wire, and reconnecting everything fixes it.
But measure the impedance on all the speakers anyways!
Feb 25, 2011 | Onkyo TX-SR304 Receiver
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Can someone tell me what the audio setting on the Onkyo TX-SR606 should be when the PS3 passes the signal as full multi-channel. My receiver always seems to say something different i.e. Dolby Digital or TV...
If you're running an optical cable from the PS3 to the receiver, best quality would be through the Dolby Digital, because that broadcasts in 7.1 HD Audio Format. There should be a way to get a default setting when the optical input is detected in your receiver.
Hi I have an Onkyo TX-SR304E. When I try to play music via a dvd/cd player, it lasts for about 20 seconds then shuts off with the STAND BY light flashing on and off.When I try to turn it on , off it goes...
The unit is in protect mode. A problem was detected in the final stage of the amp and the unit shuts down to prevent further damage to either the amp or speakers. Check the speaker wires to be sure that they are not crossed anywhere. If with the sepaker wires disconnected, the amp still enters protect mode, the problem is internal to the amp. This is usually defective output transistors. Expect a parts cost between $15-$40.
Dan
Dec 04, 2008 | Onkyo Audio Players & Recorders
Onkyo TX 304E - mp3 audio format
Hello, please try different listening modes. Thank you. Onkyo USA
Mar 30, 2017 | Onkyo Audio Players & Recorders
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Connecting a subwoofer
There are numerous systems that would be compatible with your system. Consult your dealer where you bought your RCVR..accordianman
Jan 14, 2008 | Onkyo TX-8511 Receiver
Hooking up ps3
Check system in TV Format Setup:
NTSC or PAL N
Dec 28, 2007 | Onkyo TX-SR803 Receiver
Onkyo tx-ds787
if you mean HDMI compatible, then no. There are no HDMI inputs/outputs on this receiver. Component is the best it has.
Nov 19, 2007 | Onkyo TX-DS787 Receiver
Onkyo TX-SR304 Receiver Logo
235 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
