Question about SATO CL408e Label Printer
Sato thermal printer will start printing, then stop saying that the head is open
    Problem Solver:
  • 10 Answers
Check the switch tension plate if it is align and pushing it down properly the on/off switch
Posted on Apr 15, 2010
  • 155 Answers
Esta impresora utiliza un pequeño switch que detecta cuando la cabeza esta abierta. Identifica donde esta este switch y verifica si no tiene cables rotos o esta dañado. This printer uses a small switch that detects when the head is open. Identifies where the switch and check if it has no broken wires or damaged.
Posted on Jun 10, 2009
Red light blinking
You need to recalibrate the printer with sato cx400 printer driver.
There is also option to enable Direct Thermal (no ribbon) or thermal transfer printing option.
Jan 02, 2016 | SATO CX400 Thermal Label Printer
Our SATO M-84Pro printer will randomly pause between labels when we are printing a large quantity of labels. Any suggestions?
The internal memory of the printer is limited. When printing large files the memory is refreshed several times to complete the print job. This is normal.
Aug 21, 2014 | Sato America SATO M 84Pro6 - label printer...
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
Jul 18, 2011 | SATO M5900RVE Printer
Hi, Sato CL408e, it starts printing between the labels. The feed is off by about 0.5cm. Any idea on how I can adgust that?
1) Try to calibrate the printer.
Else
do factory reset ( Press LINE and FEED At same time and switch on the printer.
Else
Change the potentiometer offset (Pitch,print) settings in the front panel.
Rgds
Mohan
Jan 21, 2011 | SATO CL408e Thermal Printer
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
I have a Sato M-8485S printer and changed my print head 2 times making sure i dont scratch it while i put it on and changed de rubber roller. But still it is well dark at the bottom but light dark after...
Lo mas probable es que requiere que la cabeza sea bien ajustada en su posicion. Lo mejor es que la ajuste un tecnico calificado en impresoras SATO. The most probable is that it requires that the head is tightened into position. The best thing is that adjust by a qualified technician in SATO printers.
Jun 04, 2009 | SATO M-8485Se Thermal Label Printer Print...
Ribbon End
Try changing setup from thermal transfer to direct thermal
Apr 03, 2008 | SATO M-8485Se Thermal Label Printer Print...
Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Apr 13, 2007 | SATO CL408e Thermal Printer
SATO CL408e Label Printer Logo
201 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
