Question about Whirlpool Dryers
No heat in gas dryer
I have a whirlpool LGR7646DQO gas dryer that spins but has no heat. Could the pilot be out? If so, how do I get to the pilot?
  • Whirlpool Master
  • 3,361 Answers
Remove the front panel. Leave the door switch wires connected.
Turn the dryer on and look for the glow bar ignitor to glow red.
This may take a couple minutes.
No glow. Replace the ignitor.
Posted on Mar 05, 2009
My whirlpool gold dryer doesn't have any heat coming from it. Could my pilot light be out?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Whirlpool Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
heatman101
Aug 28, 2011 | Whirlpool Dryers
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
heatman101
Aug 21, 2011 | Whirlpool Dryers
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
DRYER IS ON, AND SPINNING, BUT WITH NO HEAT. GAS DRYER. PILOT LIGHT LIT.
check the high limit thermostat or thermal fuse. any of these break it will not give power to the selonoids to turn on
Nov 04, 2009 | Whirlpool LGV4634JQ Gas Dryer
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
The dryer won't heat it just spins. Could the pilot light have blown out? Is there a reset button?
I need you to pull it away from the wall so you can open a rear door to look in to see if the igniter is glowing and trying to light the flame. Three possibilities. Igniter, gas coils or the flame sensor. I may be able to get you going. let me know, Sea Breeze
Jul 18, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool dryer not heating up
It does not have a pilot. It uses a glow bar ignition system. You probably have a bad glow bar if it is not heating at all part number 279311
Apr 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer works but no heat
have you checked to see if the pilot light is lite.
Mar 24, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
119 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
