Question about Sony KP-61S65 61" Rear Projection Television
Lost picture when unplugig my laptopn from the front s video 2 po
The red pilot lite comes on only
  • 294 Answers
CHECK YOUR LAMP MAKE SURE ITS NOT BLOWN
Posted on Mar 07, 2009
I have a mini max 200m pilot is lite but it won't lite pressure value is replaced all connection are cleaned please help
make sure it has enough flow and also voltage at pilot generator (red and white wires from pilot). should be around 500millivolts for the gas valve to open.
Aug 20, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
What is the flame sensor
The flame sensor is attached to the pilot light. It's down on the right side of the burner tray and usually has an orange wire attached.
The flame sensor lets the heater know that the pilot light has been lit and it's okay to open the main valve.
images?q=tbn:and9gcs_-csiy0xlxc4vgn5fxb5i4km7zxxkzfpham9qknrvchqj1v19hq
Mar 06, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot is lit,but heater will not turn on. was working fine yesterday.
this heater runs on 750 milivolts. it is created by the pilot lite. the heat for the flame on the pilot generator makes it all happen. the pilot should be covering the generator 3/8 to 1/2" from the top. the generator is about as big as you small finger. it has the wire going to it next to the pilot gas . a dirty or loose connection will keep it from working also. it connects to the gas valve with a red and white wire.turn your t stat as low as it will go and take a wire,paper clip?, and cross the red to the 3rd screw with out the white wire this should make the burner come on,bypassing the thermostat.if that works clean the wire connection at t stat
Jan 30, 2011 | Williams (5009622) Ceramic Gas Wall...
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
I don't think my pilot is lite. I need to know How to light the pilot
Hi, open the front panel of the furnace, At the bottom of the furnace you will see a gas valve with a red button, or nob of some kind. Place the nob on pilot, then push in and light the gas coming out of the pilot don't let go of the button for at least 30 seconds because the sensor will not detect flame. If this dose not work you make have a bad gas valve or a bad pilot generator.
Oct 07, 2010 | Williams (5009622) Ceramic Gas Wall...
Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
Jun 22, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Sony KP-61S65 61" Rear Projection Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
