Question about Back to Basics 600 Smoothie Plus Work Top Blender
Replacement Part I have the auto serve and the dispensing handle broke off. I would like to find a replacement.
  • 8,596 Answers
My single serve won't lock in place so it will not work what can I do? I have only had it for two months
If it is still under warranty. Get a replacement or you will be forever trying to fix it.
Dec 14, 2014 | Blenders
Ninja works with single serving attachment but not the large attachment
-Return for refund or replacement. It should never have this problem yet.
Good luck
Mai
Jun 10, 2017 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
My wife broke jar.I am loking for replacement
I have a replacement glass jar for you. My base broke so I am willing to sell the glass jar part. please email me at mimitascoe@gmail.com
Mar 15, 2011 | Juicelady JL600 Professional Work Top...
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Back to Basics 600 Smoothie Plus Work Top Blender Logo
117 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
