Question about Garden
I have a powercraft chainsaw, do you know the petrol / oil ratio ?
  • Anonymous Mar 26, 2014
    Petrol/oil mixture
    For pc40 38cc
  • 257 Answers
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Posted on Mar 05, 2009
2 Suggested Answers
  • 12 Answers
SOURCE: fuel to oil ratio.
40 to 50:1.
Posted on Jun 13, 2010
I need to know fule oil ratio for homelite super2 chainsaw
Generally small tool 2 stroke engines run on a ratio of 50:1
That's 100ml of oil in 5L of petrol
Apr 03, 2016 | Homelite Garden
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
Oil to petrol ratio
25 to 1 get 2 stroke oil from a hire shop only need a one shot mix, will do up to a gallon.
May 02, 2012 | Mcculloch 16" Electric Chain Saw Mcc3516f
What type of petrol do I get for the chainsaw
What make and model of chainsaw do you have?
Chainsaws take the same gas you put in your vehicles, however the gas must be mixed with 2 cycle oil. The ratio of gas and oil depends on the make and model.
Reply back and I will look up the gas/oil ratio for you.
Thanks,
Handie Andie
Apr 21, 2011 | Garden
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
cheers hope it helps
Aug 07, 2010 | Husqvarna Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Jul 30, 2009 | Homelite Garden
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Jul 18, 2009 | Echo Garden
Garden Logo
648 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
