Question about Philips 42PFL5332D 42 in. LCD Television
Blue light turns on and then off
42" Philips won't turn on. Hit the power button, blue light in left corner comes on and than goes off within 10 seconds.  If I let it sit overnight will turn on in the morning.  Just won't turn on when warm or ?
Please help!
Perry
  • 3 more comments
  • mrcooper384 Mar 05, 2009
    my phillips 42" 42pfl5332D/77 won't turn on. Blue power light comes on in the left hand corner, then will go out after 10 seconds. It will come on if it sits overnight and cools, but if I turn it off and back on... only the blue light in the left corner, then then the light goes off.
    This is my second post. The paid "expert" responded with "it and internal problem, get repaired"... no help.
    Is the a power supply issue?
    If it was a fuse, won't it not come on after it sits for awhile?
    What is the back light?
    I'm leaning torwards replacing the power supply... any thoughts?
    Any additional ideas? Any Philip experts that know of this issue?
    my phillips 42" 42pfl5332D/77 won't turn on. Blue power light comes on in the left hand corner, then will go out after 10 seconds. It will come on if it sits overnight and cools(?) Won't turn back on (except for blue LED indicator) after it's been on.
    thats ginko!
  • 916 Answers
It sounds like you have a bad power supply. Does the blue light blink a certain amount of time or does it just constantly blink? Does the tv make any noise when you try to turn it on?
Posted on Mar 05, 2009
  • 362 Answers
Hi mrcooper384,
There is a possibility that this is a power supply problem but it is most likely a malfunction of the backlight inverter.
In order to complete a proper diagnosis the tv would have to be taken apart and voltage readings taken from the power supply.
Im sure this is not the answer you are looking for but there is no easy fix for this problem.
If you have experience with electronics repair I would suggest you buy a service manual and start troubleshooting from the power supply.
Lone99star
  • Philips Master
  • 19,396 Answers
The fact is that if the blue light turns on and off, that means that the TV is on protection.
Protection mode is a special safety mode that kicks in whenever a faulty component inside the tv has been detected.
When on protection the TV will stay in standby, as the protection crcuit prevents it from starting.
You can unplug the TV for a couple of hours , this will reset protection circuit if there is no fault.
If instead you still have the blinking light on startup that means that something inside your TV has blown.
If you are a repairer, you start testing from the power board inside your tv, looking for leaking capacitors, and testing PWB.
If you find nothing in there proceed testing the LCD digital control board, and the inverter board.
  • 564 Answers
Unplug the power cable and leave it for 10 seconds and push and hold the power button for ten seconds. then connect the power cable and turn on
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
  • Prem  Kumar
    Prem Kumar Mar 05, 2009
    Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
    1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
    2. Make sure that the display is switched on.
    Information taken from http://www.p4c.philips.com/cgi-bin/dcbin...#
    PREM
    Genius:
  • 1,913 Answers
Change your power supply check your earhing and voltage are proepr working
    Genius:
  • 1,550 Answers
Check the fuse is proper .
Also check the backlight is proper .
  • 154 Answers
There is some internal fault on the main board of the tv. need a repair.
I let my tv play all night long i turn it off then 5 minutes later hit the power button the blue indicator light comes on but no picture or sound i play with the power button and sometimes it just turns...
you must check the power supply unit of the tv which may have bulged capacitor at the secondary output which may need to replace due to it was leak.
Nov 01, 2013 | Sceptre "42"" Lcd 1080P Tv"
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
My tv will not come on. It flahses red 7 times.
u have 2 bad capacitor on power supply , they are very small ,
Apr 15, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture on my Philips HDTV
call a tech let them check your tv if no power it will be the power supply or related circuits.if you have sound then it could be video circuit module.as you said that it dont have pictures you did not mention anything about sound.good luck
Apr 23, 2007 | Philips 42PF9830A 42 in. LCD Television
Philips 42PFL5332D 42 in. LCD Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
