Question about Ecoquest Breeze AT Living Air Purifier
Leather recliner near the unit has become "tacky".
The recliner is in a small bedroom. The unit is on a shelf near the open door, facing the door. Air conditioning intake is in the ceiling in the hallway near the bedroom door. Also noticing "tacky" feel to the handles of some weight equipment in that room. It is the only unit in the home which is 2400 sq ft.
  • Dutch7773
    Dutch7773 May 11, 2010
    The unit helps to drop particulates out of the air. Is there a lot of cooking done? Is the tacky-ness greasy, like in a kitchen?
    Dutch
  • Anonymous Mar 26, 2014
    Searching for any test results on recliner chairs
    President:
  • 389 Answers
Unfortunately this site has cut off your description of what has happened to your leather recliner, but here's my best guess...  If the handles of the weight equipment are made of rubber, then almost certainly what you are experiencing is oxidative deterioration caused by the ozone that your "purifier" emits.
It may give a fresh smell to the air, but ozone is an environmental pollutant, causes degradation of organic matter such as leather and rubber (which is how it eliminates nasty smells) and is toxic to animals (including people), often causing respiratory problems.
Writing as a qualified chemist and biologist, I would not want to be in the same room as an ozone generator, and preferably not even in the same house. My advice to you: turn the "purifier" off - permanently!  It will be better for both you and your possessions.
Posted on Mar 07, 2009
Unit will not turn on. New fuse installed.
The mesh screen filter on the back, may not be installed properly. There is a tab near one of the corners of the filter, that fits into a safety switch (much like the tab on a dryer door or washer door). It must be installed so that if pushes the trigger snugly. If the filter frame appears to be warped or bent, gently straighten it. Reinstall the filter and make sure the tab is tightly in place.
Hope this helped to solve your problem. Please let me know.
Mar 09, 2011 | Ecoquest Breeze AT Living Air Purifier
Motor runs but wheels don't turn
If you have used it for a long time then minerals in the water may have built up somewhere and now needs to be removed wither by cycling a cleaner of some sort or physically scrubbing the moving parts yourself.  The first ting to try is unplug the machine, remove all the filters, and try cleaning with vinegar. Smells bad I know but following up by cleaning with a regular detergent should remove the smell. Detergent alone will not break up the calcium, the acid in the vinegar does that. Next we need to find out what gears may have slipped or if there is a belt out of place. If everything mechanical is in working order then the cam from the motor to the rest of the unit may be shucked in which case it would depend on where it is broken to determine the best repair. Please, if you could as some problems like this are not always simple, take a look at your particular unit and provide me with some further description of what is going on.
May 27, 2008 | Venta - Airwasher LW44 Air Purifier
Tip
Air Purifier Cleaning
You bought that air purifier to help to clean the air in your home. However you have forgotten about it and now you expect it to still clean, when all of the cleaning surfaces and the filter that catches the big chunks are completely used up and covered with dust and dirt.
Here is what you need to do on a regular, like monthly, basis to keep it working well.
  1. If your unit has a filter or pre-filter pull it out and wash it gently in some warm soapy water. If the filter is a throw away one then place it in a plastic bag and dispose of it. Be careful not to throw it away before you make sure you know what to get to replace it. You may need the old one for comparison when purchasing a new one. Also take note of how you removed it and the direction of the air flow. Some of the filters are made to have the air flow in a certain direction. The filter is often located in the back side at the bottom of the unit.
  2. Take apart everything that you can on the air purifier and clean all the pieces with a moist cloth. You may need to take toothpick or something small to clean out the small grooves and crevices in the unit.
  3. Leave everything dry completely before reassembling the unit. This may take quite a while for some of the filter media. A few hours is not uncommon, be patient.
You now will have your air purifier working in top condition again
on Jan 11, 2010 | Air Purifiers
All of a sudden my purifer is no longer working I have notice the ceiling aboe were my purifer sits the ceiling is getting dark so I shut it off , it just not seem to clean the air anly longer my serial...
These units are manufactured by Alpine Air Products. Some years ago, they were sold through Network Marketing Reps.
You can contact Alpine Air Products directly at 888-675-2616, Monday - Friday (9am - 5pm PST).
That will be your best bet.
Feb 22, 2011 | Ecoquest Fresh Air Air Purifier
Took the filter off to clean it and now it will not work. What is wrong?
Looking at it from the rear, there is a small switch on the right side. There is a plastic piece on the filter that has to push in on the switch to allow the unit to operate.
Oct 17, 2009 | Alpine Air XL-15 Air Purifier
I have a new (3 weeks) Holmes air purifier. After a week of sitting on my bedtable, I noticed black sooty powder on my bed table and a week later, I found the same powder on the wall. It has ruined my...
Actually, your purifier is working as it should. The black soot is due to the negatives ions which attach themselves to the smoke/dust/dirt particles in the room and make them drop to floor. If you don't smoke it won't be much of a problem. Some minor residue will be found in and around the unit but this comes about because the negative ions make dust and other particulates fall to the floor. A quick wipe or vacuum easily eliminates this problem. Besides, I would rather have them on the floor than floating around in the air, wouldn't you?
Apr 26, 2009 | Holmes Products HAP2400-U Air Purifier
My linkage fell apart inside my Symphony III air exchanger
I have one and the spring is to open the intake and exhaust door.
Jan 07, 2009 | Air Purifiers
This air purifier has not reduced my allergy symptoms.
You are a ***** and need to get outside more ;-)
Dec 03, 2008 | Ionic Pro TURBO Air Purifier
ALPINE XL15
Hi jackkikay,
A faint buzzing sound is normal - - that's the high-voltage plasma discharge simulating lightning in a thunderstorm. If the room is dark you should be able to see a faint bluish-purple glow of the metal grid on the plate(s) inside. This should somewhat louder as you increase the setting.
It should not really be so loud that is stands out in the background of normal noises (refrigerator running for example). If the buzz is loud - - like something is shorting-out internally (loud crackling sound), that would signal a different problem - - I'd need more details about what you're observing. Approximate purchase day, specific model, number of plates, general condition of the interior would all be helpful if you deem the buzz to be too loud for normal operation.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Oct 29, 2008 | Air Purifiers
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
131 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
