Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Does the front bottom plate where the speakers are come off?
So you can vacuum or clean it? (the material part)
  • 2,992 Answers
That speaker grille does come off. There are some adjustments servicers occasionally need to get at behind it, so it usually just snaps on with some plastic fasteners holding it in place. You just need to grab it by the sides and pull forward.
Now having said that, I'll admit I'm not familiar with every Toshiba model. So yours might be different. Every one I've worked on so far has had a snap-on grille. But some manufacturers hide mounting screws under a trim strip between the bottom of the screen and the top of the speaker grille. This strip is held on by snap fasteners, and when you take it off you'll find screws holding the top of the speaker grille in place. So if the grille absolutely doesn't just want to pull off, check for that trim strip method.
Posted on Apr 04, 2009
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar...
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
How to clean the coil on the bottom of refrigertor
Use brush and vacuum cleaner.
1. Unplug the fridge,
2.Remove rear bottom cover and also front kick plate. Use bottle brush and vacuum up all the lint.
Jun 08, 2014 | Jenn-Air JCD2389G Side by Side...
Wont re-assemble
Assuming you did not remove the brush roller to clean it and consequently did not reseat it, I am guessing that the bottom plate is not reinstalling as it should. On some uprights, the bottom plate hooks in at the front and is latched in place with clamps. This can be difficult if there is interference with other parts. Give me some more detail on what works and what doesn't
Jan 23, 2013 | Dyson DC14 All floors Bagless Upright...
Freezer freezes but frig wont cool amana with freezer on the bottom
I couldn't find a repairman so I pulled the big thing away from the wall, took off the bottom front plate and the bottom rear plate and unplugged the big beast. Then using a refrigerator brush and a vacuum I carefully cleaned all the dustballs from the coils on the bottom. Then plugged it back in and in about 3 hours it was cooling normally again on a "4" setting.
Jul 13, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Pull the plastic cover off of the front unit at the very bottom. This is referred to by some as the "kick plate". Upon removing the kick plate, you should see the coils (may need flashlight) and then simply using your crevice tool on your vacuum, clean them off.
Mar 29, 2010 | Amana ABB1927DE Bottom Freezer...
How do I clean my EcoQuest Breeze?
The purifier should be cleaned about once a month and you should do the following:
  1. Unplug the Breeze before cleaning.
  2. Wipe the Breeze with a soft cloth dampened with water, vacuum the front grill to remove any lint buildup.
  3. Cleaning the rear lint screen - You can either vacuum the filter or you can wash in hot water. Allow to dry before reinstalling the lint screen. Do not use soap, it will damage the carbon material in the lint screen.
  4. Remove the purifier plate from the purifier and soak in 1 part amonia and 1 part water solution for 10-20 minutes. Gently scrub the metal grid on the plate with a toothbrush and rinse with water. Clean the metal contacts with the same solution. Allow the plate to dry overnight or use a hair dryer to dry throughly.
Dec 07, 2009 | Ecoquest Breeze AT Living Air Purifier
Isn't picking up lint. Will pick up other things like flecks of paper but will not get any fuzz or fibrous material off any rug no matter what the setting. This is a recent problem. Have owned the...
Is the brush turning on the bottom of the machine ? If not It could be cloged
up with stuff or the belt could be worn on it and it will turn but as soon as it contacts the floor it will stop turning. The belt is easy to replace by removing screws on the bottom of machine and a plate will come off . The belt can be pulled off and a new one installed by stretching it over the shaft on the motor and one on the brush assembly some may have a cogged wheel. JUST MAKE SURE IT IS UNPLUGED BEFORE DOING THIS
Oct 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
How do I change the belt on my vacuum
Turn the carpet head upside down and look for visible screws at the front edge of the bottom plate. Inspect for others further back .Once removed the plate should hinge forward and separate from the base.
Clean burned rubber from motor shaft and spin brush roll when replacing belt to check for wobble or hair and fibre wound in to ends of brush.
Sep 05, 2009 | Vacuums
Kenmore Trio 596.735073200 Frig & Freezer aren't working
Behind the removable toe plate at the bottom front there is a wire grill condenser. Using you vacuum cleaner and crevasse tool clean it out as best you can. Sometimes it helps to blow out this area with compressed air.
Next look for frost on the back wall of the freezer section. If there is frost you have a defrost system problem. Let me know what you find.
May 30, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Speakers need cleaning
You should not open them at all. No need for that. Just remove front cover, gently clean the parts beneath it with magic cloth and make sure not to press membrane. All that can be inside the box is some harmless dust and that can be vacuumed out trough the bass aperture but make sure to put vacuum cleaner on lowest suction. If covers are very dirty and made of plastic or metal you can wash them manually with dish detergent in warm water.
Apr 20, 2008 | Audio Players & Recorders
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
