Question about Home
One piece fiberglass tub cracked in the middle of basin (4'' crack
Support under tub seems to have deteriorated so when you step on the bottom there is some give. This has developed a 4'' or so crack. Can I somehow open up the front of the tub and slide a support piece under it as a temporary fix. We have been talking about remodeling down the road so I am looking to get by for a while. Can I even get under buy accessing an opening from the side.
    Scholar:
  • 80 Answers
The only sure fix is to drill holes in the bottom of the tub and shoot in a commerical grade low expanding foam to fill in the void. The foam you find a Lowes or Home Depot will not work as it is a high expanding foam and will ruin your tub. Call a reliable tub repair company experienced in this type of repair. It should not exceed 200.00 including rolling in a new floor.
Posted on Aug 20, 2009
Can a cracked BBC/fibreglass bathtub be repaired?
beautiful new bathtub and wall right over your old one
or contact a good fiberglass repair shop (boat repair place might be able to help)...
Aug 10, 2017 | Washing Machines
The casing around the jet on the tub side is cracked and is causing water to leak on the outside of the tub. This has happened to three of the 10 jets. What can I do to fix this?
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
Nov 14, 2017 | Jacuzzi Home
My Whirlpool WFW8310sw2 is leaking water during the rinse and spin cycles. After opening the bottom panel, I noticed that the water was coming around the cement. After tracing it, I found out that it is...
Hello, W/D here.
If you washer is still in warranty, you should let the company make it right.
If not, you can make repairs yourself. First, determine why the leak occurred. One common problem is a loose or damaged counterweight. If loose, it will need to be tightened up. I have seen a counterweight that was pre-stressed, with a rod between the mounting points that had broken, allowing the counterweight to hit the strainer. This can be repaired by replacing the counterweight part, or by strongbacking with aluminum, and epoxying the weight back into a solid mass. Epoxy also is useful for repairing cracks in tubs. I roughen up the area to be epoxied and apply fiberglass mesh (the self adhesive wallboard tape) to the area, and then applying J-B weld. I've never had a repair like this break. For your repair, I would recommend that you build the joint up well, with layers of the fiberglass tape and epoxy, and feather the repair out onto the drum surface area several inches. The fiberglass tape can be cut into strips and applied like a bandage, if you need to make wraps. Overlapping the joint of the tape pieces contributes to the overall integrity of the repair. Just don't put down so much tape at one time that the epoxy can't get to the surface of the drum. Several layers, with curing time in between applications is the best way to go. Depending on where the crack is, the repair is easier to apply if the surface is more horizontal than vertical as the epoxy tends to try to run until it sets, so try to place the washer in a good position, if possible. Removing the tub may make this easier for you, but it isn't critical. If you DO remove the tub, make a similar epoxy repair from the inside of the tub, if possible. This will provide greater strength and sealing.
Hope this gives you better options, --W/D--
Feb 11, 2011 | Whirlpool WFW8300SW
I have a cracked and damaged area on the bottom of my fiberglass tub insert. Can I fix it myself? Where would I find the kit needed? Thanks.
My secondary bathtub is that way. I was told it was just a surface crack and wouldnt leak. It can be fixed with a fiberglass boat repair kit. However, it would not look very good. I took clear caulk and squirted into mine and it seems to be working fine. Once you put the caulk in rub it in with your fingertip and remove the excess.
May 06, 2010 | Home
Crack in the bottom of my Kenmore washing machine tub
What is the model number? Is this a front loader or a top loader? To answer your question, yes, the tub can be replaced. You need to take a look at your warranty information to see if this can be replaced at no cost to you. Most manufacturer's warranties cover the first year against any major defects. However, some warranties are extended on certain parts. Something you may consider.
If you post back with your complete model number, I can give you an idea on how much a replacement tub may cost you, and if you have to pursue this on your own...I can give you the steps required to replace the tub.
NOTE: Marine epoxy or plumbers goop may work as a temporary fix in the mean time.
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
We have Builders #6032 and it has small hairline cracks in tub bottom. Its starting to leak into our basement. What do we do to fix it?
alot of times if you call the tub builder they have service guys who will come and fix your tub. most tubs have a 3-8 year warrenty against defects so you could get the fix for free. if not you can always try and get fiberglass resin and mix a batch up and seal the cracks yourself
Aug 01, 2009 | Hydro Systems DUO6648GWP Designer Series...
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
My porcelain covered bathtub has tons of ''spider cracks'' all over
crack in porcelain is going to affect the cased iron shell. if you don't fix them. water will seep through and cause the iron to rust.
the cause of the cracks are from the extreme temperture change in the room or the floor.
there are no easy fix for this. you can get a tub insert from any of the home center. I can tell you what the price is, since I haven't done any home remodeling for 3 years. price change.
Apr 25, 2009 | Home
2 inch crack in shower pan fiberglass floor
I repair such fiberglass shower pan liners in the Philadelphia > NYC corridor. Generally, this fix should cost you between $150 and $500 depending on the size of the shower and how many people in your area do fiberglassing. I would strongly suggest having the entire shower basin re-fiberglassed as opposed to trying to patch the hole. However, a good fiberglasser should be able to fix this in a couple of hours for a few hundred bucks. If you are in our area, visit www.CFINJ.com and contact us. Brian
Mar 01, 2008 | Washing Machines
White Plastic From Washer
Sounds like pieces of the detergent drawer might have cracked and fallen off. Check the drawer and see if you need to replace it.
Nov 01, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Home Logo
155 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
