Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
MY FREEZER HAS ICE BUILDING UP ON BOTTOM OF FREEZER & PREVENTS DRAWER FROM COMING OUT. I DEFROSTED FREEZER AND NOTICED THAT THERE IS ICE IN THE DRAIN HOLE. HOW DOES THE DRAIN HOLE WORK AND CAN I PREVENT THIS ICING IN THE FUTURE?
  • 400 Answers
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Posted on Mar 05, 2009
Ice is building up at the bottom of the freezer. No drain at the bottom.
The drain hole could be behind the rear panel at the bottom. You will need to clear all the ice and make sure the drain line is clear.
Sep 10, 2017 | Freezers
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Freezer drain is clogged, I guess, water dripping on the floor, ice buildup on bottom of second door, it has an ice machine built in, what do I do? I'm a female.
Good Morning Andi.
the good news is that the fridge is not likely doing this because you're female, and your description of what has happened with power outages sounds like that's very likely the culprit - a fair amount of melted water dripping, then power comes on and freezes water in the drain.
I don't know your specific model, or if you know where the drain is. it's likely down in the bottom of the freezer compartment. If you remove the lower drawer, or unpack the lowest area, the floor will likely slope toward either an overt hole, or to a slit/hole in the back. If there is actual ice frozen on the lowest shelf/shell of the freezer, you'll want to get rid of it.
Easiest and safest route (as in least likelihood of damaging the freezer or hurting anyone)
  1. Turn the fridge off. It won't be off long enough to risk much thawing, but you don't want the cooling coils actively pulling heat from what you do in the next step.
  2. Hot, even scalding water. Especially if there is overt ice at the bottom, pour small dribbles in at the edge. Some will go across the ice and melt a bit of the bulk. Some will trickle down between the ice and the freezer floor. Do this a couple times, then see if you can pry up sections of the ice from the floor. Pull out as much as you can of the bulk ice. You'll likely want to get a couple of towels out since you'll likely get some water on the floor.
  3. Once you've cleared overt ice from the freezer floor, pour some more hot/scalding water onto the plug, or into wherever the floor slopes to. Be patient and don't pour too big a volume. Ideally, after a few modest pours, you'll get water coming out from under the fridge. If the lower panel will pop loose, get in and use a towel to pick up as much of the water as you can. pour a bit more hot water through and verify it pours through to the floor (or possibly a catch pan).
  4. If you get this far, dry the freezer floor as best you can with the towels, replace the drawer or any unpacked foods, close the freezer, and turn the fridge back on. It will probably be back to normal.
    Good Luck!
    D
Nov 23, 2015 | Freezers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice collecting under bottom of Freezer drawer/ seal round door intact/ food staying frozen/ Ice is cleared periodically but then builds up again
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
Jul 04, 2009 | Hotpoint Freezers
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Our 19.6 cf whirlpool "commercial" freezer (sn EV201NXMQ0312 building up ice in the bottom under the slide out basket. It actually builds up enough in a month or so to keep the basket from sliding out....
the ice build up is from a frozen drain line. you will need to remove teh rear cover in the freezer and you will uncover a coil at the bottom center there is a drain hole that allows defrost water to drain out. defrost any ice then flush the line out with warm water. if it doesnt clear right away you may need to use a large syringe or possibly a turkey baster to force warm water into drain.
BTW the door not sealing is not related to this problem. good luck peyton
Jan 27, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Whirlpool Freezer
your defrost drain is frozen remove the rear bottom panel on the freezer at the back insede the freezer and clear the defrost drain there will be a hole under the ice you just need to clear the drain not buy a new freezer
May 19, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frost Free Freezer
sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 04, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429 Logo
2,939 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
