Question about Brother HL 5250DN Laser Printer
WHEN PAPER FEEDS THROUGH PRINTER COMES OUT WRINKLED. HL-5250DN BROTHER PRINTER
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Posted on Mar 05, 2009
My paper keeps jamming after I changed the drum of my printer in my Brother HL-5250DN printer-- it seems that I touched something when I did so.
1. Unplug the printer.
2. Remove the drum.
3. Make sure there are no obstructions. Check for pieces of paper obstructing the feed and any small objects such as torn paper or even a stray fingernail.
4. Replace the drum.
5. Plug in the printer.
6. Attempt to print again.
Mar 02, 2011 | Brother HL 5250DN Laser Printer
How do I get rid of the dots on my paper
Download the user guide -
Google: Brother HL-5250DN PDF
Then give your printer a through cleaning following the instruction in part 6.
If that doesn't fix it you need a new toner cartridge.
Dec 14, 2010 | Brother HL 5250DN Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
Only first page wrinkled
the fuser assy. in the back of printer is the cause of this problem,replace fuser assy. or continue using printer like that until fuser give up.
Sep 13, 2009 | Brother HL 5250DN Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN printer on Linux operating system
you have to set it in the printer settings to do that
Mar 05, 2009 | Brother HL 5250DN Laser Printer
My brother hl-5250dn printer is spitting out very wrinkled paper
It could be the fuser unit. If you open the door on the back of the printer and pull open the paper path tray you will see an orange colored roller. If this roller is wrinkled even just a little it will wrinkle the paper. I purchased fuser roller units for my 5240 and 5250 printers and replaced them myself and that corrected the problem. I got the fuser units from ebay.
Jul 30, 2008 | Televison & Video
Brother HL 5250DN Laser Printer Logo
430 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
