Question about Lexmark Office Equipment & Supplies
Lexmark X3690 printer works directly from laptop but although the print job is in the print queue is will not print over network.
  • blackie1832 Mar 05, 2009
    Have tried reloading drivers on remote laptop. Still not prin ting.
    Sergeant:
    Champion:
  • 224 Answers
Go to the control panel, select printers, right clik on the printer and seect properties. Then go to the ports tab and make sure "Enable bidirectional ..." is selected. The rpinger should work on the network. You might have to restart your pc for it to work.
Posted on Mar 05, 2009
  • 8,197 Answers
Make sure the network will allow you to share the printer.
  • 154 Answers
Reinstall the driver and check again, this will works.
    Brigadier General:
  • 3,614 Answers
make sure that your computer on the network has complete access on the printer, better do reinstalling again the network printer for that
  • Lexmark Master
  • 19,396 Answers
You need to reinstall the drivers.
  • 1 more comment
  • Ginko
    Ginko Mar 05, 2009
    The printer installation on the local usb connection is different from the installation done on network connection.
    The computer will see the networked printer and the USB cable connection as two diffeent printers.
    You will probably need to reinstall the printer as a network printer from printers in control panel.
  • Ginko
    Ginko Mar 05, 2009
    To reinstall the network printer follow the instructions on one of the two websites below, depending if you have XP or Vista:
    YouTube - How to Install a Network Printer in Windows XP
    How to install a network printer | Windows Vista
    Remember that the files on printer cue for the local USB connection are separate from printer cue for network connections.
    If you plan to use this printer as a network printer, do the installation procedure above , and set as default the newly installed network printer.
    Using at same time a printer on network and USB cable can mess up your computer settings.
    Use either network or USB installation and set the printer as default.
  • Ginko
    Ginko Mar 05, 2009
    If the printer is already on the network, and it cannot be seen by the laptop as a remote (network ) installation try disabling all firewall/antivirus software on your laptop to install the printer.
    If you have a firewall software you may also need to add the printer as an exception on your firewall settings.
    If still no luck after doing that , then connect the laptop to the router or switch hooked up to the prionter using an ethernet cable and set the printer using the cable connection, and setting browse for printers on the network. After setting is finished it should also work as wireless when you unplug laptop from network cable.
    If that still does not work, you may need to set up the printer by using its IP instead of browsing from printers on the network.
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
My Lexmark s605's print queue won't clear, and so the printer has stopped working altogether
Please follow the steps below to clear the print queue and restart the print spooler of your computer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark Interact S605 All-in-One Color...
Hi. My lexmark z640 printer has stopped working. When i double click the z640 icon on the desktop the window opens and says that the current job is deleting, this has been like this for hours. tried to...
Try to clear the print queue first before sending a new print job. Follow these steps to clear print jobs stuck in the print queue(for Windows):
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
3. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 27, 2011 | Lexmark Z640 InkJet Printer
I have just replaced the black cartridge on my hp2605 color lasetjet and now nothing prints - the light flashes & It says it is printing, but nothing comes out, also will not print test page or any of...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 2605dn Printer
Network Printer Queue in Peer to Peer Network
Hey there the printer may need additional ram, thats where it stores the printer que,
Brand: Kingston UPC: 196891036256should be the model for your printer. However, You can go back to where you had it connected to a pc directly and just share it, there really isint any downfall to this, except that the pc attached must always be on and should have a little extra ram.
Dec 27, 2009 | Office Equipment & Supplies
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
I have a Lexmark 5490 connected to a D-Link DPR-1260. The D-Link configuration utility installs the printer on my Vista Home Premium laptop as the default printer and recognizes that the printer is...
Check your windows firewall or your antivirus.
Disconnect that for a while and delete all pending documents (queue).
Send a new doc to print and see what happen.
Usually those program are blocking the communication between printer and computer.
If this is your case, set a rule on your antivirus program.
Have a great day!
Pablo :-)
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
My print jobs hang up in the queue
Test pages are printer generated not from the computer. Have you checked Microsoft help on this? make sure you are on line. Go to My Computer /Help, then when the help pages comes up Type in print spooler See what you get Rephrase the question if the answer you seek is being missed.
Jun 21, 2007 | Dell Inkjet 720 Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
