Question about Adobe Acrobat 6.0 for PC
Time & Date Issue
My Pentium III system is not keeping time and date. Each time I start the system after it is shutdown the time, date and BIOS setting comes back to original factory set-up. I have changed the mother board battery. But the problem continues. How can I solve the issue??
  • 38 Answers
Try replacing the battery with a brand new one, Last time i checked Staples stocked these in energizer brand. Also make sure that it is firmly snapped in on the motherboard. I've had the same problem before and it was because it was just barely not fastened all the way in.
Good luck Susan!
Posted on Mar 05, 2009
I forget bios password for HP DL160 G6 server, how do i reset the password ?
  1. Shutdown your server.
  2. Go inside the server, and remove the CMOS battery. It should look like this.
3. Be sure to power down your server before taking it out. Be aware that once you take this out the system will forget a lot of it's time settings. This is the battery that keeps the computer's memory of time, date, and BIOS password when it's shutdown.
Apr 14, 2013 | HEWLETT-PACKARD HP ProLiant DL160 G6...
My system time and date is not set
Go into the BIOS settings then to the Date and Time and set the Date and Time, Save the settings and Exit.
IWhen you boot up later and the Date and Time is incorrect then the BIOS battery is flat and a new replacement battery is needed. The BIOS battery keeps the laptop's configuration plus the Date and Time settings unless the battery is flat.
Apr 16, 2012 | Dell Inspirion Computers & Internet
My Toshiba Satellite p15-S470 Laptop lost date and time after shutdown. When i start my laptop it will not proper on and show orange light, after closing and out battery from laptop 2 to 3 time then it is...
try accessing your bios on your laptop and change the date on it. To access the bios just press F2 or F10 once you press the power button. Once you are inside of the bios locate the settings for date and time, then that's the time you can change and save it before you exit.
Hope it helps thanks.
Sep 15, 2011 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
I set date & time on my acer aspire, but it will not stay set it just stays on the date & time ive set. help! fred.
Welcome to FixYa!
-try doing these steps.
1) Enter the CMOS setup
-to enter the CMOS or BIOS setup, shutdown the computer completely -then once you press the power button to turn it on, keep on tapping on F2. (for some computer its F1, del, F10)
2)In the main or system setup screen you should be able to see the date and time. Using your arrow keys, navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
These steps may vary for your BIOS; additional help, information, and simulations can be found on the BIOS help page.
3)after you have configured the time and date, save your settings and exit.
4)if it still would'nt hold the time you have setup, it could be a possible virus issue, or the CMOS battery on your computer could be degraded.
Hope this steps would help!
Have a great day!
May 25, 2011 | Computers & Internet
Bios date is not being saved
it has to be the battery contacts, the motherboard is loosing contact with the battery which is why it keeps resetting itself
Jul 06, 2010 | Computers & Internet
I have a Gateway laptop model no. M622-UCX which continues to prompt for the system date configuration in cmos setup during start. It also cannot remember the date and time I entered several times and...
When a laptop/computer prompts for a BIOS date and Time setting every time you boot up, this indicates the BIOS battey is flat or nearly flat. This BIOS battery needs to be replaced and the BIOS Date and Time setting needs to be configured etc.
Mar 14, 2010 | Gateway Computers & Internet
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
Bios
Hi, if you're system does not keep the correct date & time it is possible the cmos/bios battery on the motherboard has reached it's max life span. The bios battery recharges only when the system is on. In many cases even when the system is on & you correct the date & time & notice the time is off the battery needs replaced.
92208a8.jpg How to replace cmos battery:
http://www.computerhope.com/issues/ch000239.htm
Mike
Aug 01, 2008 | Intel Motherboard
Want to find out manufacturers date regarding
Goto BIOS Settings there you can find the date of manufacturing. If you did not see there remove your battery and and powercables and reinsert them and check the bios data and time date and time will change to manufacturing date & time.
Or
Try to install Sis Soft Sandra from Internet there you can find all the details you need.
or follow the link
http://download1us.softpedia.com/dl/e5fe876dd31eccc2fd8968b503772714/47457344/100005280/software/system/info/san1234.exe
Hope this will be helpful.
Nov 20, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Adobe Acrobat 6.0 for PC Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
