Question about Reddy R115DT Oil Filled Utility Heater
REDDY HEATER 115 FAN RUNS BACKWARDS ON START UP
FAN RUNS BACKWARDS ON START UP. DOES THE MOTOR NEED TO BE REPLACED?
  • 232 Answers
Yes, the secondary windings are bad.
Posted on Mar 09, 2009
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
My reddy heater 115 pro starts, but shuts off after about 5 seconds of running , i replaced the filters and nozzle about 2 years ago
Here is a service manual:
http://www.desaparts.com/service_manuals.html
If the flames actually starts but the unit shuts off after 5 seconds you need to check the pump cover on your heater to make sure you have no cracks in the rear cover.
This could be from low pump pressure but most often this problem is caused from a defective control board.
Oct 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kersone reddy heater won't start, just buzzes
The R150B uses motor #097308-06, has a split phase motor. The secondary windings, which give the armature a jump-start, have gone bad. The motor is not serviceable. Try reddyparts.com - they seem to have the most parts.
Feb 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Motor Running backwards.
flip ur wires on motors. just reverse ur polarity.
Jan 29, 2009 | Reddy R115DT Oil Filled Utility Heater
Pro 115 Reddy Heater
The ignitor is bad, there are still parts available from reddyparts.com very simple to install.
Jan 24, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy heater 115 just turns on then shuts off
a new flame sensor is in order, if you have spark and it blows fuel then thats the answer. you can get one thet will fit from Mr. Heater for 3 bucks. the wires are different so just splice the to your old wire harness, there is no wrong way to hook them up.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy R115DT Oil Filled Utility Heater Logo
206 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
