Question about Canon LaserClass 2060P Plain Paper Fax
Can i use any ink film? - Canon LaserClass 2060P Plain Paper Fax
  • 59 Answers
The Canon LC2060 uses a powdered toner in replaceable cartridges. It does not use ink film.
Posted on Mar 20, 2009
Error 5100
1) Smearing or scratches on the timing
**** film;
clean the timing **** film.
2) Foreign material or paper debris that
obstructs the carriage movement;
remove foreign material.
3) Ink cartridge conditions;
re-set the ink cartridges.
4) Cable connection
5) Part replacement:
- Timing **** film
- Carriage unit
- Logic board
- Carriage motor
Aug 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
The printouts produced a column of smear ink, some time with scratch at the top & bottom of the smeared column. the last part of the paper of the column leaving some hot ink dust
That sounds like the fixing film in the fuser has begun so shred itself. the film usually runs off centre and get crunched up at the end. A new film and possibly pressure roller will sort it out. Its fun to fit though!!
Aug 19, 2011 | HP LaserJet 1020 Printer
How to print if the ink color can't out??????
I assume that you're not getting ink from the cartridge?
Check to make sure you remembered to remove the protective film from the terminals of the ink cartridges.
There will be a plastic pull tab to help you spot the film.
Lyle
May 03, 2010 | Canon PIXMA MX310 All-In-One Printer
Opening the cover
This model print on Thermal transfer technology: there is a black film inside the fax.
Open the cover from the rght side with the green or grey button.
You can then see the black film.
Usually, the top part is the new, the lower is th used.
To know if the film is near empty, you can remove the film from its place and see which side is bigger.
Good Luck.
Mar 13, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Philips fax machine inkroll film replacement
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
May 07, 2008 | Philips PPF-531 Plain Paper Thermal...
New ink roll in Philips fax Magic 2
Here is what you do
OPEN MACHINE
CLOSE MACHINE
SET TIME AND DATE
OK
OPEN MACHINE
CLOSE MACHINE
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
Replacing film
try to sensor check.. press "menu # 9000 # *(ateris) 815" then remove the ink film.. try to trigger the white lever found near at thermal head can see it if you remove the ink film.. then look at the LCD.. while triggering the lever,, see if there is reacting on screen while triggering the lever sensor.. if no reaction or sometimes there is reaction.. you need to cleaned the sensor at the digital board....
Nov 01, 2007 | Panasonic KX-FPG377 Plain Paper Thermal...
Canon LaserClass 2060P Plain Paper Fax Logo
old marine
old marine
