Question about True T-49 Side by Side Refrigerator Commercial
Freezing everything t-49
T,stat
  • True Master
  • 3,361 Answers
Yes, replace the t-stat.
It is the only part that sends power to the compressor.
Posted on Mar 05, 2009
Why does everything freeze in my T-49 True refrigerator
The cooling coil is probably frozen up. Shut it off and leave the door open over night. Start it up in the morning and see if its more accurate. Down the road you may find you have issues like leaving the door open in high temperatures, maybe the coil is plugged with paper, ice, dust etc. and needs to be cleaned, or maybe it was improperly charged by the last service man that worked on it. The charge should have been weighed in with a scale by the ounce. Good luck and hope this helps.
Jun 20, 2014 | True T-49 Side by Side Refrigerator...
The fridge section freezes everything: milk, meat, etc.
Make sure thermostat is not set too high if okay then sounds like you need new stat....
Feb 22, 2011 | Microwave Ovens
Does not freeze
first you must find out if it is a refrigeration fault or an electrical fault. if it is refrigeration - it usually is a gas leak. this will cause the fridge to run and run and not cool anything. if it is electrical. it may run and run and freeze everything - T/stat. not run at all - t/stat fault or short cycle on and off - compressor or relay fault. hope this helps.
koolman77 (refrigeration technician)
Feb 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 03, 2011 | HP LaserJet P3005n Printer
Mini Fridge freezing everything
Yes, thermostat and when they go bad they eiter sop , keepgetting colder or out of calibration, I will see if I can find one, Really any small two wired refrigerator thermostat wil be fine, Sea Breeze
Mar 18, 2010 | GE SMR03BASWW Compact Refrigerator With...
Delfield ColdPro Refrigerator, Commercial unit, two door reach in... recently has begun to freeze.... Temp setting stays at 37F and for some reason, just on occasion it will drop to 0... and everything...
Intermittent failure of thermostat is the most likely problem.
Check the temp sensor to make sure it is clean.
You can check for voltage coming out of the thermostat when the unit is working improperly.
If the setting is on.... say, 36, the temp is... say, 26, and there is still voltage coming from the T-stat telling the compressor and fan motors to operate, then you have a bad T-stat/sensor.
Most T-stats for that type unit do not have a separate removable sensor, its all one part with a sensor on a long tube/wire.
You can probably buy one from your local refrigeration supply warehouse for less than 35 bucks.
If it were a more consistent problem, I would say you have clogged coils or low refrigerant. But if most times it works fine, and then just randomly will not shut off, that's likely a controls thing. = T-stat.
Jan 02, 2010 | Delfield (F18WC60) Commercial Refrigerator
Temperature control does not work. Unit freezes everything no matter where the temperature control is set (Marvel Wine Refrigerator)
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Oct 12, 2009 | Marvel (6SBARBSG) Wine Cooler
Freezer defrosts and unfreezes everything. A day or so later it refreezes.
most domestic freezers do not have a defrost control. .90 percent of them freeze and every few years enough ice builds up that you have to unload and manually defrost them. so what is probably happening is the stat is sticking in hte off position and not recognizing the call for cool when the temp gets up. if you catch it off and thawed try tapping the stat gently after the temp is getting way warm. if the box comes on and starts freezing again then the stat is sticking in the off cycle and needs to be replaced. usually under 75 dollars and fairly easy. two wires connect in any order.the stat itself has no in and out requirements. power in and power out when it closes. there may be a ground wire usually green and smaller connector attached to some newer stats. look close and you can see the difference. usually the voltage connections are next to each other and the ground is off to the side or end. stat is usually behind a plastic cover inside the freezer. good luck, disconnect power when you change stat of course.
Nov 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
Jun 01, 2008 | Kenmore Refrigerators
True T-49 Side by Side Refrigerator Commercial Logo
335 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
