Question about NetGear FS516 Networking Switch
I HAVE 2 NETGEAR FS516 SWITCHES. BOTH NEED A NEW POWER SUPPLY.
THE POWER SUPPLY IS INTERNAL AND HAS A NAMEPLATE THAT SAYS:
DELTA ELECTRONICS, INC
MODEL: ADP20KP REV. B
Can I buy replacements for these and where?
Replace capacitor C3 47uf@25V. It will fix that ADP20KP 90% of the time.
Posted on Mar 24, 2009
  • 1 more comment
  • tony Dec 21, 2011
    tegbjg thanks for tour tip, it worked for me and restored my busted FS516 switch
  • John Tester
    John Tester Jan 25, 2014
    Me too. Didn't have a 47uf @ 25V. Used 100uf @25V, worked a treat
  • Marco Bellotto
    Marco Bellotto Jul 07, 2015
    Me too.
Hi, My power supply has failed on FS516. See item 370123981061 on Ebay £35 or Offer. I have just offered £25 and was accepted + Free Carriage !. They are 2nd Hand but Tested. A few more available. Until it arrives I cannot say what it is like.
Posted on Jul 12, 2009
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
Noisy fans on a desk-top pc Model Acer Veriton 1000. Besides replacement for new fans, can brushless fans be serviced or lubricated?
The Veriton 1000 I have has 50mm fans (length and width). 80mm are the wrong size. They are 15mm thick, 12V, 0.2A. For some reason, these seem to be more expensive than many other fans.
Jul 13, 2012 | Computers & Internet
Need to replace fans on netgear GSM7248 that is out of warranty. Where can I purchase them
I bought them from Digi-Key. Just google the part number on the fan for specs and match that up with the parts at digi-key. My GSM7248 has new fans, new low voltage caps, new heatsink retention clips and a new power supply. They should be selling these POS switches for $250.
Aug 12, 2010 | NetGear ProSafe GSM7248 48-Port Gigabit...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
Dead Netgear jgs516dead Netgear jgs516 . No lights. the inside power supply outputs 1.5V instead on 5v. Delta PS # ADP-40VP Where do I buy a replacement? I am in San Rafael, CA
Well, I believe the product you have carries life time warranty with NETGEAR. Hence, you can get it replaced from NETGEAR. Please log a support case with netgear at http://my.netgear.com
Regards
Anand Gupta
Apr 20, 2010 | SMC Netgear 16Port Gigabit Ethernet Switch...
No power light on FS516. Fuse Ok. No obvious signs of any internal burn-outs
Hi replace the power adapter and check if it helps. If the issue persists and the unit is under warranty then please log a complaint with netgear using the below address my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 12, 2009 | NetGear Computers & Internet
NetGear FS516 Networking Switch Logo
1,443 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
