Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Cannot take picture
I'm using a canon 1000D with kit lens 18-55mm. My problem is that I cannot take picture in autofocus mode. No beep, no flash and no picture taken. Nothing happen but I can take pictures in manual focus mode. Need help here.
  • Anonymous Mar 16, 2009
    I have exactly same problem, it works fine with manual focus but on autofocus it just keeps moving the lens never focuses and take snap.
  • Adi Sunardy
    Adi Sunardy May 11, 2010
    Have you tested it with another lens, it might be lens issue, not the camera...
    Problem Solver:
  • 17 Answers
Check the switch on the side of the lens, it should be in "AF" not "M". The switch turns the motor in the lens on and off. If the switch is set to "M" the automatic mode on the camera will not work.
Posted on Mar 16, 2009
Flash should pop up automatically when you operate camera in easy mode (green square on dial selector) in low light conditions. If using in manual modes press the button on the left side of the lens mount. To fire the flash without taking a picture press the button used to zoom out when viewing pictures.
If your flash does not work at all then there is probably a fault with the charging circuit or firing circuit.
May 11, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
I have a canon eos 1000d and as i was shooting i turned on the noise reduction on and i think i manage to take another 3-4 shots after that.Then i realized for some reason the lens was properly focusing...
This is a long shot but you can try to remove the battery for a few minutes and that should "reset" your camera. Put the battery back in and see if it works, if not you can try calling Canon service at 1-800-652-2666 and they may be able to help you.
Good Luck!
Jun 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon 1000D's autofocus isn't working properly. But the manual focus is.
hi could you tell me how it does not work? you might have just lens problem..
Jun 04, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Hi I bought my canon 1000d on september 2009 and a year later the autofocus doesnt want to work. In the viewfinder on the far right a number 9 has a green dot flashing next to it. Please help!! Ruthven...
The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I am using Canon 1000D dslr for more than 18months, it was working fine until last Sunday. I went outside and started taking few shots... it was not focusing properly (or should I say not at all!) and...
The autofocus motor could be be broken, or the lens may not be communicating correctly with the camera. One thing that can help if it's not communicating correctly is to clean the lens contacts. If you take the lens off, you should see some gold plating on the plastic on the side of the lens that attaches to the camera. You can clean it by lighting rubbing it with a new, CLEAN pencil eraser. if that doesn't work, you may need a new lens unfortunately. best of luck!
Oct 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Will this Lens fit the Canon DSLR 1000D
Yes, it will fit Canon 1000D.
But I'll recommend you to try lens in a shop before buying - picture quality can be low.
Jun 24, 2010 | Rokinon 6502600 mm f816 for Canon
Focusing in low light can be difficult for the autofocus system and sometimes you will need to use the manual focus, you can select the magnified image and see if that helps
See the online manual - page98 refers to how to magnify the image - using the magnify button - changes between 5X 10X and full screen
To help the camera autofocus there is an assist beam - this takes the form of flashes from flash to help the AF system focus - make sure it is ON - there is a custom function full details on Page 157 C.Fn III: Auto focus/Drive 6 AF-assist beam firing
FYIThe support site for this camera is here, including online manual
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
Cannot preview shots in lcd with new Canon Rebel xs 1000d
There are two modes to the XS's Live View system, selectable via Custom Function 7. Live View is disabled by default, by the way, so you'll need to find this menu item in Settings Menu 2 to turn it on. The two options are called Quick and Live modes. Quick mode works as most Live View modes do, dropping the mirror when you press the AE-Lock button (marked with an asterisk) to use the conventional phase-detect autofocus system. This temporarily blacks out the Live View image, which makes it impossible to know that you're still framing the subject and holding your AF point in the proper place.
That's why they added the second mode, which they call Live, but is better described as contrast-detect autofocus. This works just like a digicam, reading the image from the imaging sensor while adjusting the lens for the setting that produces the most contrast in the image. A small square appears in the center of the image area, and you can move it around with the cross keys. Just like Quick mode, unfortunately, you have to press the AE-Lock button first until you hear the focus confirmation beep, then press the shutter button to fire. It's a little slower at times than phase-detect mode, but it gets the job done. Live mode is really better for tripod work, where you can place the AF area right where you want it and confirm focus onscreen.
Both modes offer the ability to zoom in on your live view, excellent for confirming focus before capture. Using the Magnify button just right of the AE-Lock button, you can zoom in 5x or 10x, then press the AE-Lock button to focus if you like; but of course you can't confirm framing in that mode.
Jan 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
269 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
