Question about KitchenAid KSM150PS Artisan Series Stand Mixer
HOW DO YOU GET THE SQUEAKING NOISE TO STOP - KitchenAid KSM150PS Artisan Series Stand Mixer
  • susan
    susan Jul 22, 2014
    the sqeaking noise comes om the bet that is on the alternator so everytime i start the car it makes that loud squiling sound eventually it stops but it is loud
    Problem Solver:
  • 12 Answers
You must indicate where the squeaking is coming from. If its only squeaking, move on. There's other people here with down time problems. It'll stop squeaking or stop running eventually. If it stops working, then write in!
Posted on Mar 16, 2009
  • lukewhitf68 Mar 26, 2011
    Hello, there is no way that you can get the squeaking to stop, it happens when the kitchenaid has a thicker cake batter in it or as it gets thicker, mine does it around the speed 3-4-5 then in 7-8-9-10 it stops so i dont worry about it, hope it helps ;)
Why Kitchenaid mixer kv25g0 stop working after five minutes
We need more information if we are to help. Does it do this every time you turn it on or did it happen once and it will not run anymore. Is there any noise when you turn it on or does it smell or spark when you turn it on. Please more info.
Sep 05, 2014 | KitchenAid KV25G0X Stand Mixer
KA 600 is making a clinking noise when mixing.
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
Hi! my mixer is about over 10 years old , its making a sqeeking like kind a noise and its spains i think a bit to fast , could you tell me what do you think is the problem
I had your same issue with the speeds. I think you need to adjust the speed through the speed control panel.
Open the back spherical cover on the Kitchenaid KSM90, the area with one screw on the top. You should see the speed control panel, a black and gold square connected to wires. There should be three large silver screws - two on the top, left and right - and one on the bottom. If you turn the top two screws clock wise the machine slows down at lower speeds. When you adjust the bottom screw, the higher speeds are effected. This process is called "tuning" and you can find an online video how-to through sites like Youtube.
As for the squeaking, you maybe replace some of the grease inside of the machine. Food grade gear lube would do if you are up for the challenge, but kitchenaid also sells a grease for their stand mixers for a pricey $20. It isn't hard to put in new grease and clean out the old but requires a lot of disassembly.
~ I am not an expert but a hobbyist. This advice is only my opinion based on limited experience. ~
May 26, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a 600 watts stand mixer, one time i put too much flowers and it just stop mixing in the middle and making the loud jam noise. now it won't complete the circle and alway jam half-way and stop...
It sounds like you have a stripped gear. I, too, had this problem when my bride dropped a wooden spoon into the bowl. You'll need to disassemble the mixer and determine the part(s) that need to be replaced. With a google search for parts for your model, you can not only locate the exact part, but can also get exploded diagrams for your model. Very handy indeed for disassembly/reassembly. I'd get the diagrams first and then determine the parts needed.
Hope that this helps you.
Best regards, --W/D--
Jan 22, 2011 | KitchenAid ProLine 600 Stand Mixer
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer motor makes loud grinding, squeaking noise.
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Oct 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Theres a loud squeaking noise when the mixer turned on
Hi. These mixers normaly make a lot of noise when in operation. Go to the shop that sold it to you, or any place that has these units on display and ask them to turn on the mixer for a demonstration. If their mixer does not make the same noise, then contact Kitchenaid Customer Service and ask for a replacement under warranty. If this solution assists you, please rate it. Good luck! ricardok45
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Feb 11, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
1,582 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
