Question about IBM ThinkPad R51 Notebook
When i switch on my laptop, before booting it is showing fan error and then it turn's of automaticaly...if im press acces ibm putton then it is booting but the fan is not running
  • karikal Mar 06, 2009
    thank you ...it is realy helpfull for me
  • 38 Answers
Hey Karikalan! Make sure you don't run your computer without the fan on! This can cause permanant damage to the CPU as well as other components.
Sounds like you need a new CPU fan for your laptop. These usually range in price around $60 - $130. They can be installed by a computer expert, or if you want you can try it youself. Be careful though Processors and internal components are very sensitive! To install it youself you'll have to remove the bottom part of the computer's casing. Once that's finished you should see a part that looks like a mix of plastic / metal with a fan about 1" big in the middle of it. This is the component you'll want to replace. A new fan can be obtained from IBM or you can order an equivalent on Ebay. Usually they are cheaper this way.
Hope this helps!
Posted on Mar 05, 2009
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Evey time I try to boot my ibm thinkpad type 2647 nothing happens and the fan keeps going from high to low any ideas?
Whe you switch on the laptop please go to Bios and check the hard disc is dictacted or not. Other wise when you switch on the computer please press F11 button 4 to 5 times and select the boot option from the hard disc. If it not working need to show service center.
Sep 23, 2010 | IBM ThinkPad T23 2647 Notebook
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says...
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
Fan Error
You may have a faulty fan, check to fan, it should spin freely, if not the fan needs to be replaced. The fan and heatsink assenble may also be clogged with dust, remove the dust and vacuum to clean.
Jun 07, 2009 | IBM ThinkPad R51 Notebook
Disable boot up password in R51
You could open up the R51 and remove the CMOS battery. This would reset the password.
Here is a link I found that allows one to hack the BIOS password:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Or try this fixya thread:
http://www.fixya.com/support/t1641914-ibm_thinkpad_r51
Feb 06, 2009 | IBM ThinkPad R51 Notebook
T23 fan error
This is a commin IBM issue fans going Bad ... to try and free it if it's just dust you can actually blow into the vent with compressed air and free up the Fan ... The IBM T series all check fan before powering up.
The replacement is not too difficult to do.
The safest air is the can type to blow in there.
LB
Good Luck
Oct 29, 2008 | IBM ThinkPad T23 2647 Notebook
Re: t40 ibm fan error
Are you talking about the original fan being good or the replacement? If it's the original, then your problem may lie with the processor or mainboard. Try the download first, you will need to access another computer to make a bootable disc for the download to clear it. I believe with IBM you can make a bootable floppy or CD. If you have a floppy for your machine, some don't. Once you've made the disc or floppy, you will need to enter the boot menu, and boot from the proper drive. I'm out for the night, but I'll be back in the morning. Let me know.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
Problem out of the blue
This is an operating system fault. Some of your Windows files are deleted Or Corrupt. I,d suggest re-install your operating system. or alternatively performing a system restore, if you have a restore or boot CD.
Mike @ Compurepair.
Jul 23, 2008 | IBM ThinkPad G40 Notebook
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad R51 Notebook Logo
69 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
