Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
As soon as I release the pully from starting the lawn mower...it dies...what is the problem? thank you
  • 1 more comment
  • orch_87 Mar 05, 2009
    The rope pully assembly. I pull the rope to start the mower.....as soon I release it.....the motor dies.
    Thank you so very much!
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr o,could you tell me what pulley you are hanging on to when starting mower,are you talking about the release handle shutoff.
My mower starts but dies as soon as I release the key
I would suspect the ignition starter switch is defective, it is located at the back of the ignition key lock cylinder.
May 24, 2016 | Garden
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Aug 01, 2015 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When blades start to engage it dies what could that be
you have a bad safty switch replce it the one that goes to the brake start switrch
Jul 01, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
STARTING ROPE BROKE AND UNABLE TO START MOWER
Hi,,,,replaceing the rope is easy, just takes sometime. first, take the cover off the engine. turn the cover over and rope pully should be right there. Measure out 8 foot of new rope. burn both ends of rope so it don't fray. get all of the old rope off the pully. here is where an extra pair of hands come in handy. by hand rotate the rope pulley 6 revolutions, now have someone hold the pulley, then feed rope thru the cover and thru the pulley rope opening, then tie a knot in that end, now slowly release the rope and it will wind itself onto pulley, now put rope thru the handle and tie knot, now put back togeather and go mow your lawn,,,lol
Sep 22, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
20 Hp 42" Deck Lawn Tractor: I have a craftsman rider that starts idels and dri...
sounds like one of the pullies is locked up . check all the pullies for free movement the plastic pullies are junk. replace with metal ones if you find a bad one.
May 17, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 1994 G4000 craftsman riding lawn mower i got it running but when i let off the pedel the engine shuts off the switch for the brake/clutch is fine and i replaced the selonoid and key start also the...
If electrical ( the motor shuts down like you turned the key off) its likely the rider presence switch ( seat switch).
If the motor is pulled down and dies as if its uncapable of handling the load check the drive system. Remove deck and check drive belt and pulleys. Pull the belt off of a pulley for slack and with the tranny in first and the brake released you should be able to turn the large pulley on top of the tranny easily which should cause the tractor to start to move. If you cant turn the pully there is something wrong in the tranny.
Nov 30, 2009 | Craftsman Garden
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
126 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
