Question about Lands Phones
I installed a Panasonic T170 expansion board on a KX-TD1232. I mounted it at the bottom of the door. It does not work. I have not programmed anything yet or turned off/on the power. The manual states that the system default is C, E1, E2 for poistion 1,2and 3. Should I relocate this unit to position 2? I need help troubleshooting this problem and to program this system to accept this board if needed. The purpose of this install is to add 2 telephones.Will the telephones work as the other 16 phones currently in use? All the existing phones are set at default system settings.
  • 6 more comments
  • info167 Mar 05, 2009
    I've already tested from amphenol. I need help configuring the system and confirming card position.
    When position 1 did not work I replocated to position 3. This position did not work either.
    Is the system deafult actually C, E1 and E2, or do I need to program 109? Should I relocate to positon 2 which should be E1
    no dial tone from the amphenol
    I neep help configuring the T170 for a
    KX-TD1232
    I tried position 3 and no DT. do i have to program 109 parameter and recycle power?
    This D1232 system has (2)50pin amphenol connectors for station interface. 8-ports on the top and 8-more on the bottom amphenol. The expansion board also utilizes an amphenol connector.
    please only respond if you have worked on this product.
  • Lands Phones Master
  • 2,460 Answers
Just like the lines and amps, Panasonic starts from the bottom and works to the top. Keep the card in the bottom position and go to 109 and alter the display so that E1 appears in the setting, then save it, exit programming, and power the system down and back up.
Yes, the new extensions become 117-124 by the E1 probramming.
Carl
Posted on Mar 05, 2009
  • Carl Navarro
    Carl Navarro Apr 07, 2009
    30 days and no response? What's the deal?
  • 1,800 Answers
Look through the instalation of one ofthe 16 other phone and set Up the phone just like the other!
    Genius:
  • 1,550 Answers
You need to relocate to position 2.
    Brigadier General:
  • 3,614 Answers
better do check first the line. also try testing it on a different handset.
  • 1 more comment
  • micromaster
    micromaster Mar 05, 2009
    check the telphone lines, since you dont get any dialtone it could be a wrong connection on the wire.
  • micromaster
    check the PBX settings, choose type 2 for your fone
  • micromaster
  • 19,396 Answers
Try first changing position to 2 or 3, try also unplugging all cables for five minutes to reset the system before switching to position 2.
  • Ginko
    Ginko Mar 05, 2009
    I do not know if you can read my post, but follow instructions on the link below, I quote:
    "There are two things you will inevitably come across when working with
    Panasonic phone systems: Krone blocks and DDK connectors. DDKs are used
    on every telecom-based port of your system as well as the door phone /
    door strike terminals. Panasonic use both 4- and 6-pin DDKs, 4-pin for
    COs, cell sites etc; and 6-pin for the extensions. If you open the
    front panel of your KX-TD1232 you will see a row of DDKs running from
    top to bottom, grouped in four blocks of four. These are your extension
    ports, port 01 being at the very bottom, port 16 at the top.
    Each connector is capable of carrying three pairs of wires. In
    telecomms, everything is referred to in pairs otherwise it starts
    getting rather confusing. Of these three pairs, two are actually used -
    one for analogue, one for digital. When wiring the system, the first
    thing I did was to take 8 lengths of CAT5 solid-core network cable and
    attach two pairs to each DDK. As CAT5 has four pairs, I run two DDK's
    worth down each span of CAT5, hence eight lengths.
    And the reason for using CAT5? I had plenty knocking around
    :-) Telephone cable is actually quite similar, but CAT5 has a slightly
    different twist applied to the conductors. For telecom systems, it
    makes very little difference.
    from 01 - First Steps
  • 154 Answers
Reset th phone and try again.
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How to block outgoing call via PBX panasonic KX-TD1232 DBX
You have this posted in the wrong product category. Please select another category appropriate to the problem.
Aug 29, 2012 | Cars & Trucks
Kx-td1232
You have to change the usb to a virtual serial port to do it.
Aug 06, 2012 | Panasonic Kx-td1232 Super Hybrid Pbx...
How can i se the numbers i have received and the missed calls in my panasonic phone KX-T7735
Hello, I have a Kx Td1232 with a KX-T7735 and program 96 and 99 does not work. What do I have to do? Thank you.
Sep 14, 2011 | Panasonic KX-T7735 Corded Phone
How to reset or know Panasonic KX-TD1232 Admin Password without loosing existing settings and programming.
On the D1232 box open the main door and there is a switch front lower right (normal - clear)... switch to clear and go to the main or number one phone and hit program *# ******* (7 stars should do it)
once your logged in hit 107 and then next to view current password
once you have the password you can switch it back to normal and log in with that password by hitting Program *# (password)
Mar 27, 2010 | Panasonic Lands Phones
No dial tone kx174
That's a trick. Pull out the card on the bottom of the cabinet and see if you get dial tone from the cards in the middle and top positions.
I think A1 and A2 mean extension cards of which you can derive 32 extensions, and the 16 analog ports on the base cabinet. I could tell you about the TDA-100 or 200, so I hope you didn't pay a lot of money for the 174's.
Carl
Nov 07, 2009 | Panasonic Lands Phones
Is tha possible to get 25 single lines on 16SLC card(50 pin)
The 25-pair Amphenol connector is just something the industry uses because it's standard and easy. In a TDA system, the 8-port C.O. Trunk card uses the first 8 pairs, a 16-port the first 16 pairs, an 8-port Pana station card uses the first 24 pairs, 3 pairs per extension. The last pars don't have any hardware behind it and are connected to nothing.
The only phone system that I remember where all 25 pairs are used is a 1a2 10 button set and, maybe a Comdial system where the 25th pair is the common audible for station 17 :-)
Carl
May 22, 2009 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
80 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
