Question about Lands Phones
I have a Vextra large button phone model # 4848-18 I do not have the manual to store numbers into the memory. Can you help me with steps? I see the store button but do not know the steps. Mary D.
1. Hit the store button
2. Type in the phone number
3. Hit store again
4. Hit the button you want it stored to M1, M2, or M3, if using the little auto dial buttons you need to hit the Auto button and then the little buttons.
To auto dial you just hit M1, M2, or M3. For the little buttons you need to hit Auto first then the little button. There is no beep when you hit the Auto button but it is working.
Hope that this helps
Posted on Mar 28, 2009
How to install phone no. in ET 3576 to memory
I think most Radio Shack phones work pretty much the same. They don't have a manual available for yours so I'm not absolutely sure, but I've had a couple of their phones. To store a number in those, it was just three steps:
  1. Press MEM
  2. Enter the number to dial
  3. Press MEM again, followed by the location button (on phones with single buttons for emergency numbers) or the memory location (one or two digits depending on the number of memory locations)
Try these steps and see if it works for your model.
Aug 03, 2011 | Lands Phones
I have a VTECH phone model Vt 1122 and I do not have manual still and I need to know how to insert numbers in memory.
You can get the manual here. Here's what it says about storing numbers:
Storing a Phone Number in the One-Touch Memory Locations
  1. Lift the handset.
  2. Press the PROG button.
  3. Dial the telephone number you want to store (up to 16 digits).
  4. Press the one-touch button (M1, M2, M3) where you want to store the number.
  5. Hang up the handset.
Storing a Phone Number in the Two-Touch Memory Location
  1. Lift the handset
  4. Press the MEM button.
  5. Press the dial button (0 to 9) where you want to store the telephone number.
  6. Hang up the handset.
Please take a moment to rate this solution if it's what you needed. Thanks for using Fixya!
Jul 04, 2011 | Vtech Lands Phones
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
How to set clock
look on the back of the clock for the company that built it and the model number, look up the company on google and find support, then search for the model number and download the manual or get the phone number and call them. the first one almost always works
Aug 16, 2008 | Vextra Computers & Internet
Programming a number for memory
Memory
Nov 03, 2007 | Uniden Cordless Phone
How to store phone numbers in the memory
i need infor how to store # on XACT XC1255
Oct 13, 2007 | Panasonic KX-T7730 Corded Phone
Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Oct 06, 2007 | GE 2-9438C Corded Phone
Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Jun 27, 2007 | Northwestern Bell Classic Favorite 52860...
Storing numbers in memory
Call conairphone, they will tell you over the phone how to sotre numbers. You can find their number by doing an online search. If you have an old model phone follow these steps. You have to make sure your batteries are working. Leave phone in cradle - press and release store button - dial the number - press and release store button again - press the button you want your number stored.
May 07, 2007 | Conairphone CID 244
Lands Phones Logo
921 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
