Question about Peachtree Software Peachtree Complete Accounting 2004
I cannot open the company from any of the workstations.
I use a peer to peer network. I lost all data on host hard drive and had to reformat it. After re-installing all the software, including Peachtree Complete 2007 multi-user, I have not been able to open the "company" from any workstation in the network. OS is Windows XP Professional. The Peachtree company opens fine on the host computer. There are two errors that pop-up when I try to open from any of the workstations:
1. If I am "not" logged in on Peachtree on the host computer the error note from a workstation is: Another user is using the feature I am trying to use.... (note: not exact wording)
2. When I'm logged-in on Peachtree on the host computer the error note from a workstation is: "Not a Valid Peachtree Company"
Workstations are properly connecting to the host computer. Datapath is pointing to host default and is accessible. Removed and re-installed Peachtree on everything. Installed latest updates: SR6. Verified permissions and drive mapping. Did everything recommended in Peachtree.com knowledgebase support. I can connect to other devices on the network, i.e. printers. I don't have a service support program with Peachtree.
Need help, Please.
Tony
  • 12 more comments
  • Tony Mar 05, 2009
    I restored data from a backup prior to the problem. I still have the same problem. I believe my problem is with the Peachtree software and not the hard drive; plus I don't have a recovery disc for the hard drive.
  • Tony Mar 05, 2009
    After re-installing all the software I created a new network. And to eliminate possibilities, a few days later I created a second new network. All workstations are pointing to the correct network.
  • Tony Mar 05, 2009
    Peachtree allows users on workstations to log-in even if nobody is logged in to Peachtree on the host computer. The only requirement is that the host computer must be turned on and a user logged-in to the computer (not Peachtree).
    Logging-in to Peachtree from a workstation only happens after the workstation has linked to the company on the host computer. Which is my problem, I cannot get the workstation to link to the company data files.
  • Tony Mar 05, 2009
    ACDR: I have a multi-user license from Peachtree. However, please explain what is "crack"?
  • Tony Mar 05, 2009
    I have re-installed the Peachtree software at least 4 times on all computers in the network. And yes, after every re-installation I download and installed the latest updates. In this case SR6.
  • Tony Mar 05, 2009
    At this point I'm willing to do anything. I will re-install Peachtree once again.
  • Tony Mar 05, 2009
    I just did a search and there is no PPAM140.ini file in my computer.
  • Tony Mar 05, 2009
    Thanks! But I don't have a support plan with Peachtree. I called but they wouldn't help unless I purchase the plan.
  • Tony Mar 05, 2009
    Went to "My Computer", did a "My Computer" search for file PPAM140.INI and again, did not find this file.
  • Tony Mar 05, 2009
    Re-checked, permissions are ok.
  • Tony Mar 05, 2009
    I am using Peachtree version: Peachtree Complete Accounting 2007 (SR-6)
  • Tony Mar 05, 2009
    Don't forget about me. Please help!
  • Tony Mar 05, 2009
    I like to thank everybody for their help, but I found the answer to my problem in Peachtree online support site called "Peachtree Accounting Community", under "cannot open file z:\company.dat
    Even though I checked and re-checked permissions and folder sharing never occurred to me to select the box in folder sharing that "Allow network users to change my files". I only checked the box "Share this folder on the Network".
    What got me to this site was my curiosity with PPAM140.INI and why it was not in my files. I did a google search and there it was.
    Can I get a refund? Just kidding! Thanks for all the advise.
    Tony
  • Tony Mar 05, 2009
    I found the answer somewhere else, but I have to thank you for leading me to the answer.
    Thanks,
    Tony
    New Friend:
Thank you for your help!!
For QuickBooks hosting service visit http://www.hitech-cloud.com.
Hitech Cloud is a leading hosting service provider providing quality service to enhance your business. QuickBooks Hosting Peachtree Hosting Solution
Posted on Jul 02, 2015
    New Friend:
Posted on Jan 16, 2014
  • 916 Answers
Check to make sure that the other computers are in a group that is allowed to access files on the host computer. To do this go to the host computer and make sure that the permissions are set correctly.
Posted on Mar 05, 2009
    Sergeant:
  • 183 Answers
Check your firewall setting and if it is not marked as allowed then mark it. and if you get still same problem then call at 877-495-9904
or visit following website for live company assistance:
Click here for live assistance
Good luck
    Scholar:
  • 93 Answers
Have you verified that when you reinstalled Peachtree to the computer, you have also installed any relavent updates which may have been installed After you did the original installation?
Often, regular updates can update the database also, which is why they ask you to log out all users before Proceeding. If you have a newer version of the database than the software is expecting (due to no updates), then the software will not be able to open the database, and could easily spring up the problems you are having here.
  • 5 more comments
  • Jay Selway
    Jay Selway Mar 05, 2009
    OK, if you go to your windows folder, check the PPAM140.INI file for the path to the Peachtree data files. At least, it must be X:\Company - you cannot map directly to the folder where the data resides, you have to be one level up from that.
  • Jay Selway
    Using my computer, find the file I mentioned, and check the path in that matches the folder where your data files reside. Let me know the outcome :)
  • Jay Selway
    Can you verify which version of Peachtree you are using?
  • Jay Selway
  • Jay Selway
    There is a free data checker available here, make sure you have a backup beforehand though. Click Here
    *not tested*
  • Jay Selway
    Have you tried the data checker?
  • Jay Selway
    Ahh - Glad you found it Tony - all the best mate. :)
    Genius:
  • 1,913 Answers
No your software need multi user facility may be after new instalation your software need some crack for multi user.
    Brigadier General:
  • 3,614 Answers
Hi there ,
i would like to know if you already setup a networking on your unit. you can find this wizard on the network properties, you must add and create a network connections
let me know
  • 154 Answers
Insatll some recovery software to recover the hard drive.
  • crysiszone Mar 05, 2009
    try a more-- unstall the software and install again,
    i think you miss any option......while you install it.
  • 19,396 Answers
Save a backup immediately, try resoring a recent backup, if that does not work, then reinstall the software.
  • Ginko
    Ginko Mar 05, 2009
    RE:"1. If I am "not" logged in on Peachtree on the host computer the
    am trying to use...."
    A: that may be normal , you need to log in to access to a database.
    RE: 2. When I'm logged-in on Peachtree on the host computer the error note from a workstation is: "Not a Valid Peachtree Company"
    A:
    1 you are not logging in as correct user on host computer, or you are using wrong login on workstation.
    Verify login information from host and terminals.
    2 you have delete your company name from company list.
    Ensure that the name you are opening after login is the good compny name for your database. Sometimes there are similar company names stored from the past.
    For example if your company is called 'Datainc' you may have saved a similar name like 'data inc' or 'the datainc' in the past, this can also lead to this kind of problem.
    3 your data file is corrupted.
    In this case reinstall the latest backup after trying to save a backup of current data file, in this case you usually have data loss.
Error code -6210
  • QuickBooks File Doctor
  • Important: If you already have a version of File Doctor on your computer, proceed with downloading and installing File Doctor from this article to ensure you have the latest release.
  • Once the download is complete, double-click qbfd.exe and follow the on-screen instructions to install the QuickBooks File Doctor.
  • Once the File Doctor is finished installing, it will automatically open. If not, double-click on the green File Doctor icon on your desktop.
  • Note: If you do not see it opening, look for a green wrench icon in your Windows taskbar.
  • If you see a message that you need administrator rights to continue, click Yes.
  • Select one of the following options:
  • o Both file damage and network connectivity - if you suspect your company file is damaged, or you see a 6xxx error when you try to open your company file (data file problems).
  • o Network connectivity only - if you are using QuickBooks in a multi-user setup and get an H202 error when you try to open your company file (network errors).
  • If prompted, enter the Admin password for your company file, and then click Next.
  • Choose one of the following options, if prompted to share your company file:
  • o Yes - if you are running File Doctor on the computer hosting the company file (your Server).
  • o No - if you are running File Doctor on a computer that is not hosting the company file (your Workstation).
  • Proceed according to the results in the following table:
for more help call 1-855-383-7236 or visitQuickBooks Tech Support
Nov 09, 2013 | Intuit QuickBooks Pro 2007 Full Version...
Lose password
If you are using windows XP, try site below. Possibly they may also have procedure for other version but I no longer look for it. http://www.windows-help-central.com/lost-xp-password.html
If you don't have important file in your unit or if you have a backup copy of it , and you have all the installer available, another option is just to reformat your unit and then reinstall the OS and all other softwares you are using.
If your are to reformat though, suggest you partition your hard disk into two. Use drive c to install the os and all your software. Use drive d for your data. This way you can reformat your drive c in case something bad happen and still retain your data in drive d. Note that a failure in the hard disk itself will lose both data in drive c and d so its imperative that you always backup your data.
Mar 01, 2011 | Computers & Internet
Cannot connct to wi fi
A guide in .PDF format has been included on your hard drive that provides instructions for installing and configuring both wired and wireless Ethernet networking on your notebook. To access this guide on your hard drive, from the Start menu, point to All Programs, Gateway Documentation, and then click Gateway Networking User's Guide. The following are some of the topics included:
  • Learning the Basics
  • Creating a Wired Ethernet Network
  • Configuring Windows for a Wired Network
  • Configuring Windows for a Wireless Network
  • Creating a Wireless Access Point Network
  • Creating a Peer-to-Peer Wireless Network
  • Turning Your Wireless Emitter On or Off
  • Sharing Your Resources
  • Troubleshooting Your Ethernet Network
A copy of this guide is also included on your Application and Drivers CD.
Dec 18, 2010 | Gateway Tablets & eReaders
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
1 TB External drive, unable to open (data of 80% is there)
You can't format without loosing data. You should get a professional data recovery company to look at the drive. http://techrxgb.com is my recommendation.
Jun 01, 2010 | Western Digital My Book Home Edition 500...
What does SCSI mean?
SCSI- Small Computer System Interface
It is a set of standards for physically connecting and transferring data between computers and peripheral devices.
May 29, 2010 | Microsoft Windows XP Professional
When I plug my my Hitachi SDM/205 250GB Simple Drive into the usb port a pop-up window appears and says that it needs to be reformatted. Have I lost my data?
Yes, but there are many recovery software that you can download from the internet.... so don't worry, try 4shared.com by searching Recover My Files which is very effective. Please note to format your HDD using Quick Format rather than Full Format.. Good luck..
Apr 20, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Wht does peer to peer mean
A peer is like a workstation which contributes it's resource (hard disk space,speed,Bandwidth etc.) without the need of central coordination (servers).They are both suppliers and consumers of the resources.
In simple words if you have noticed P2P clients like uTorrents,Bittorrents and many other and you want to download a file...you first download the torrent file--run it--and you start downloading it in 'parts'(consumer) from different people who already have downloaded the files and also you will see that you are using some of your bandwidth in uploading too (supplier) which means other people are also downloading from your workstation.You can even stop someone from downloading the file from your end.
This is what peer-to-peer is all about.
Dec 13, 2009 | Computers & Internet
2002 Cadillac ignition turn
  • A network is a group of computers (often called nodes or hosts) that can share information through their interconnections. A network is made up of the following components:
    Computer systems (nodes or hosts)
    Transmission media--a path for electrical signals between devices
    Network interfaces--devices that send and receive electrical signals
    Protocols--rules or standards that describe how hosts communicate and exchange data
    Despite the costs of implementation and maintenance, networks actually save organizations money by allowing them to:
    Consolidate (centralize) data storage
    Share peripheral devices like printers
    Increase internal and external communications
    Increase productivity and collaboration
    There are several ways to classify networks. The following table lists several ways to describe a network.
    Peer-to-Peer In a peer to peer network, the hosts provide and consume network services, and each host has the same operating system. Advantages of peer to peer networks include:
    Easy implementation
    Inexpensive
    Disadvantages of peer to peer networks include:
    Difficult to expand (not scalable)
    Difficult to support
    Lack centralized control
    No centralized storage
    Client/Server In a client/server network, hosts have specific roles. For example, some hosts are assigned server roles which allows them to provide network resources to other hosts. Other hosts are assigned client roles which allows them to consume network resources. Unlike peer to peer networks, hosts in a client/server network have different operating systems. Advantages of client/server networks include:
    Easily expanded (scalable)
    Easy support
    Centralized services
    Easy to backup
    Disadvantages of client/server networks include:
    Server operating systems are expensive
    Requires extensive advanced planning
    Geography and Size
    Local Area Network (LAN) LANs reside in a small geographic area, like in an office. A series of connected LANs, or a LAN connected across several buildings or offices, is called an internetwork.
    Wide Area Network (WAN) A WAN is a group of LANs that are geographically isolated but connected to form a large internetwork. When implementing a WAN, remember to provide local access to user resources to prevent a high rate of WAN traffic.
    Participation
    Private A LAN or WAN for private individual or group use which may or may not be secure. Examples include home and organization (small business, corporate, institute, government) networks. Intranets and extranets, although related to the Internet, are private networks. Both an extranet and intranet are tightly controlled, and made available only to select organizations. An extranet is made available to the public and an intranet is made available internally.
    Public A large collection of unrelated computers, with each node on the network having a unique address. The Internet, for example, is a public network. Because computers are unrelated and many companies and individuals share the same communication media, the public network is by nature insecure.
    Signalling
    Baseband Baseband signalling allows one signal at a time on the network medium (cabling).
    Broadband Broadband signalling divides the network medium into multiple channels, allowing several signals to traverse the medium at the same time.
Jul 08, 2009 | 1995 Cadillac Seville
Peachtree Software Peachtree Complete Accounting 2004 Logo
2,577 people viewed this question
Top Peachtree Software Computers & Internet Experts
Gene Jakominich
Gene Jakominich
Level 1 Expert
Don A
Don A
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
