Question about Curtis-Mathis Televison & Video
MY TV IS SMOKING BURNING INSIDE AND IT IS ONLY A
MY TV IS SMOKING BURNING INSIDE AND IT IS ONLY A LITTLE OVER A YEAR OLD CAN IT BE REPLACED?
    President:
  • 2,992 Answers
Can the TV be replaced? Certainly. Stores are full of replacement TV's.
Can the parts in yours that are smoking be replaced? Possibly. Some parts are generic and can be found at companies that sell TV repair parts. But other parts have to come from the manufacturer, and they are not always available or are too expensive to make the repair worthwhile.
Should you get this TV repaired? It depends on what kind of a TV it is (you didn't give a make or model), its age, how much damage was done by the parts that smoked, and what it would cost to repair compared to replacement.
The best solution is to have a TV technician check the set and give an estimate if it's a large-screen or otherwise costly model (or you just really want to keep the set). Or use this opportunity to replace the set if the difference in price is small.
Posted on Mar 05, 2009
1998 astra car is smoking on accelaration
It's time for an engine rebuild. Or you could get a reconditioned engine installed. All depends, if the car is in good condition and worth fixing. But it is a 15 year old car. Might be time to upgrade.
May 15, 2014 | Cars & Trucks
My car is burning threw oil like supper fast
year, make, model, engine size?
How does it run?
Do you see a lot of black smoke out the tailpipe when you accelerate?
do you see anything leaking?
Apr 04, 2013 | Cars & Trucks
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Smoking out the back and burning smell inside.
check for a cracked head that smoke you see is probably antifreeze coming out of the coolant trench in the block itself or could just be a bad gasket on your head
May 06, 2010 | 2004 Mazda 6
Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Sep 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Smoking
Couple things I would look for first the condition of the blade do you see any buildup around the teeth like something has burnt on it. Also look into the area around the blade under the table (unplug saw first) to make sure that something hasn't dropped into it rubbing blade causing smoke. Also turn the blade by hand to make sure turning freely. The smoke could possibly be coming from a bearing. If it less than a year old Bosch has a pretty good warranty and you might look into that also. Let me know and I will dig deeper into it.
Jan 11, 2009 | Bosch 4000 - 07 Electric Table Saws
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Sony model KP-41T65 no power, smoking
Hello All,
The component you are talking about is not a diode, it is a capacitor, and if it is burning it has shorted, which means that it needs to be replaced. You will need a schematic and a multimeter. Now since you all thought that this component was anything but a capacitor, I would not suggest that you attempt repairs on your own, because this section is dangerous, and can kill you if you are not careful. I would suggest that all of you get a qualified TV technician to examine your sets and affect repairs on it.
I hope this helps,
Thank you,
Shuttle83
Aug 14, 2007 | Sony KP-48S75 48" Rear Projection...
Televison & Video Logo
315 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
