Question about HP Photosmart D7160 InkJet Printer
D7630 new yellow ink was replaced in printer. The screen showed the cartridge was full, the printer went into its startup ritual and cleaning when the message came back that yellow cartridge is empty?
SOURCE: False empty ink cartridge message
Found this solution on another webpage: http://www.fixyourownprinter.com/forums/printer/50063
Hope it help.
Posted on Apr 08, 2008
Tirzo
  • 94 Answers
SOURCE: Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Posted on Jun 11, 2008
SOURCE: canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Posted on Jul 18, 2008
SOURCE: New Cartridge error message
Did you check to make sure there is nothing covering the cartridge? I know that sounds dumb but that is what happened to me-I had mine refilled and it would not work and when I took it back in they said well-you just take this off here-it was a tiny piece of tape that was almost invisible!
Posted on Jan 25, 2009
Soulvisitor
  • 1113 Answers
SOURCE: Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Posted on Jan 26, 2009
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Printer won't print - error 1203
Tell me how long the printer sat with empty cartridges? More than 30 days?
You may want to deploy this trick: take new ink cartridges out, put them to the side. take the hair dryer and for 2-3 min, blow hot air around the area and clean up the ink with alcohol swabs until clean! Also clean with alcohol, the contact points and surrounding area. Reinsert the ink and try and see if the printer recognizes new ink.
May 07, 2014 | Lexmark P4350 All-In-One InkJet Printer
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
Hi
You need to replace the Yellow cartridge
with a new one couse the old one either
has expire or has problem with the chip
on cartridge
ps vote us to keep us alive
Nov 06, 2010 | HP Officejet Pro L7680 All-In-One InkJet...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
I just replaced the yellow ink cartridge but it
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jul 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
Just changed the yellow cartridge. The printer says it's full. No ink. Same thing with last cartridge. Tried deep cleaning.
Ok I understand the printer says its full but are you saying your computer says no ink? or that it prints no yellow ink?
Ok assuming you mean that it prints no yellow ink, the culprit ususally means that the print head needs replacing! Call Canon with your model and you can buy the part for new print heads for your printer
Mar 16, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
New Ink Cartridges display low
yes it is not original you buy a new original one then show ink position
Jul 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
HP Photosmart D7160 InkJet Printer Logo
235 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
