Question about GE WBSR3140DW Top Load Washer
Ge toploading washer will not agitate. agitator moves, spins out. need to remove the agitator to check the gears. how do i remove the agitator
  • mi3dguy Mar 11, 2009
    fills, spins and drains but doesnt agitate. how do you remove agitator to check gears etc.
  • Anonymous Mar 15, 2009
    washer pills, drains and spins but ill not agitate...
  • GE Master
  • 3,361 Answers
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
My 8kg toploader is only agitating one way how do i check the agitator gear box is there something causing this ?
its called a brake arm white thing under neth the machine with an arm hooked on to some thing its not the gear box
Jan 17, 2013 | Samsung SW62ASP Top Load Washer
My washer fills,will not agitate,but will spin to empty. why? #2090 ge topload
That dang drive bell has failed most likely. It has a plastic spline in it that wears smooth with time. Yank off the agitator to get to the spline. themobilian_2141.jpg
I have a service manual here
Apr 06, 2011 | GE Washing Machines
Ge toploader will not agitate
check the bell under the adgitator if ok transmission
Jun 23, 2010 | GE WDSR2080D Top Load Washer
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
I need to remove GE topload washer agitator
Pull up hard on the agitator. It will come up.
Mar 21, 2009 | GE Washing Machines
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
578 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
