Question about EliteGroup P4M800-M7 Motherboard
USB 2.0 (Chipset VIA 8237) ECS P4M800-M7 Unknow Device
My S.O.: Windows XP Professional SP2 PT-BR (Brazilian Portuguese)
My Motherboard: ECS P4M800-M7 (Chipset VIA 8237 - 4USB 1.1 and 4USB 2.0).
When plugin my pendrive Kingston 1g 2.0 in USB 1.1 know sucessful.
But plugin my pendrive in USB 2.0 don't know my device.
All is properly connected. The driver installed is the of the Microsoft Windows XP SP2. Into the site from VIA don't have drivers xp SP2 only to SP1. In some foruns what find the Internet they say what that's a problem of the chipset VIA. Don't know solution. They say too that can be a bug of the driver HUB usb 2.0 and the microsoft sends the patch for email (there isn't link for download). I send a email, but the Microsoft dont answer me.
Very Thanks,
John FelixI have the same problem. The usb 2.0 hub worked when i first
reinstalled windows xp pro. Then did upgrade to service pack 2
then 3 and the usb hub would quit working when windows would
load. It would quit when windows loads Mup.sys. I have tried
installing the via updates but nothing works.
    Genius:
  • 1,913 Answers
It is your usb drivers update related problem.
go to device manger in my computer properteis then uninstall all usb drivers.then insall drivers form here .
http://www.download.com/VIA-USB-2-0-Host-Controller-Driver/3000-2098_4-10163319.html
Posted on Mar 05, 2009
  • 564 Answers
Thank You For Choosing FixYa!!!
If you Wish. I will take remote Control of your computer and I will try to Fix it.
Click Here, It will Take you to a Page, where you can see download Button.
Click on the Download Button, Open and run it. It will be automatically Connect to me.
Note: Link will Only Work for 15 mins. So Click on the above link as soon as you get this message.
  • EliteGroup Master
  • 19,396 Answers
Unplug computer power cord for ten minutes , if computer is a laptop also remove the laptop battery at the same time, as the problem may be caused by accumulation of electrostatic charges on USB, and draining power can help.
  • 154 Answers
Check all connection... and wires on the mainboard.
    President:
  • 1,314 Answers
Have you tried plugging the device into other ports?
I have a ECS P4M800-M7 (V3.1) motherboard , does this motherboard supports Intel Dual Core E5700 ?
this motherboard supports the following
LGA775 socket for Intel Pentium 4/ Celeron D/ Pentium D processor
FSB 800/533 MHz
so anything above that might not work or just simply be a waste of money
the e5700 will fit as it's the same socket configuration as the motherboard but here's the rub, the 5700 is only compatible with motherboards that have intel chipsets and, according to the website, your motherboard doesn't have an intel cjipset, but a via chipset.
so the simple answer is no!
http://ark.intel.com/Product.aspx?id=42801
http://www.ecs.com.tw/ECSWebSite_2007/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Specification&MenuID=52&LanID=0
Apr 17, 2011 | EliteGroup P4M800-M7 Motherboard
I need a user's manual for my Via P4M4A Pro mainboard. Via won't respond to my requests. Help!
Hi.
Via usually only make the chipset - not the motherboard. Find the manufacturers model number printed on the motherboard then go to the website and download the manual.
If you had for example an ECS P4M800-M7 you would go to
http://www.ecs.com.tw/ECSWebSitP e/Products/ProductsDetail.aspx?detailid=531&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
Jan 19, 2010 | VIA Computers & Internet
An error occurs "usb device not found" when using flash drive or
you can connect your usb at back of cpu,,,,,may be it work.you should connect your usb on different ports
Mar 11, 2009 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Os installation
Mabye the disc is scratched, or SP3 has some fixes that allow it to install, and SP2 doesn't.
Oct 26, 2008 | EliteGroup ECS P4M800-M Socket...
Front panel usb
Step 1: Decide weither you have one or two USB cables joined together, it should look like a 4 PIN header.
Step 2: Get your manual from ECS: http://www.ecs.com.tw/ECSWorldWide/Index.aspx?MenuID=0&LanID=9
Step 3: Install the 4 PIN header the right way +5V, - DATA, + DATA, GND on the motherboard, refer to the manual if you get stuck.
Hi, John
The USB 1.1 and USB 2.0 is a big issue regarding technology, the 1.1 has maximum speed of 12 megabits where as 2.0 has upto 480 Mbps. And all USB 2.0 devices are compatible with 1.1. Windows XP Home Edition and Windows XP Professional are both fully USB 2.0-compliant with the correct drivers.
So in your case it must work properly. But if the USB 2.0 from microsoft got currepted or badly updated by some thirdparty USB 2.0 driver then it will not work. I have been faced this problem. After doing some stuff I found that if I uninstall the USB drivers and reinstall it from microsoft driver then it works.
So, just go to the Device manager and un-install the USB drivers, then reboot the system to parmanently delete the removed driver. Then install the driver from Windows XP CD.
good luck
Thanks
Iqbal
Mar 25, 2008 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
167 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
