Question about Indesit W 83
CONTROL PANEL PROBLEMS WITH AN INDESIT
My indesit
w1e167 control panel either goes off completly or shows F-12 on it , the last wash i managed to do didnt spin either please could you advise me thanks you T Anderson
  • 75 Answers
Hi check all connections on the display module under top,and check connections on main module at the rear right hand side,f12 can indicate communication problems between the pcbs
Posted on Aug 03, 2009
Replacement indesit witl62 ,electronic control panel
Check with a local appliance parts supplier.
Oct 16, 2016 | Indesit Washing Machines
How to turn on child lock wash machine indesit innex xwsc 61251 ?
The Innex XWSC 61251 does not have a Child Lock or Control Panel Lock feature. The only way to completely disable the washer buttons would be to unplug the unit. The manual is available on the product page: http://www.indesit.co.uk/appliances_i/Washing_Machine_XWSC_61251_W/pid_F085657UK/40.do . The direct link to the manual is http://www.indesit.co.uk/indesit/_pdf/manuals/19512007300_GB.pdf .
I hope this helps.
May 31, 2016 | Indesit Washing Machines
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Keeps tripping the electric indesit wdg1295w washing machine
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 16, 2011 | Indesit Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
My indesit W1E167 1600 washing machine is flashing F-05, is there anyway I can unlock the door? It seems to go through the wash cycle but then perhaps gets stuck on the spin?
Error code F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Remove hose onto pump, check for obstruction here and in the pump.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Select Brands Washing Machines
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Washing Machines Logo
561 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
