Question about Kenmore 24 in. 16032 Built-in Dishwasher
My clean light is flashing....call service to check heater?
Manual says to call service to check heater circuit???
  • 1 more comment
  • pfeiferonthe Mar 14, 2009
    It made a grating sound and then quit. Clean light is on. Tried to do the hot wash and dry buttons, all lights came on, I pressed normal wash and start, but it will fill with water, and then stops doing anything. Is there a way to program this? is there anything to check?
  • marsh1buster Apr 10, 2009
    my clean light is flashing. When I try to start the start button flashes 3 times (red) and doesn't start. I tried to drain and restart, but it did no good. PLEASE HELP!
  • porschebo372 May 24, 2009
    Just tried this and VOILA PRESTO...it worked....
    thanks so much.....
    Versastyle Guru
  • 188 Answers
F the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 05, 2009
-high temp wash
-heated dry
-high temp wash
-heated dry
Posted on Jun 11, 2009
Clean light flashes and dishwasher will not start
As per the manual for the dishwasher, this error code means that there is a problem with the heater circuit and that you call it in for service.
http://www.kitchenaid.com/digitalassets/MLPDF/User%20Instructions%20-%208531778.pdf
Nov 26, 2013 | KitchenAid 24 in. KUDI01FLSS Stainless...
My 2001 Dodge Durango Seat heater switch light is flashing. How do I fix the problem?
That's means you have a malfunction on the system. Must be take to a dealer for check up. Can be the heater element is bad, unplug or wire is shorting out the circuit.
Feb 03, 2013 | 2001 Dodge Durango
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
Rheem-Tankless-water-heater I am showing a C2 then 11 flashing on my thermostate. what is wrong.
Before calling service technician, open following links for common error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are start point for troubleshoot.
C2 11 is 'no ignition' or 'gas shut off vale is not open'
Gas shut off valve handle must sit parallel with gas line.
This kind of error code can be air in gas line, improper grounding at electrical outlet, bad igniter, shorted solenoid, loose connections, etc.
Most tankless manuals recommend yearly service, and that type of work usually covers cause for most common error codes: for example checking gas pressure, gas line, air in gas line, clean and check burner and combustion parts and igniter, inspect that vent condensate is properly draining and vent has good draft, clean water filter, clean air intake, check for loose wires, delime heat exchanger, test outlet with circuit analyzer etc.
Aug 11, 2011 | Water Heaters
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Heater circuit
whirlpool dishwasher won't go into washing cycle
Dec 31, 2009 | Whirlpool Dishwashers
Model # 665.17032402 Clean light is flashing. Manual says to check heater circuit. How is the heater circuit checked? How is the heater element assembly replaced?
You need to check the thermostats in the heater circuit as well. The element is held in place my 2 nust from the bottom where the wires attach.
eric
Jun 29, 2009 | Dishwashers
Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Nov 27, 2006 | Kenmore 24 in. 16023 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
667 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
