Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Door broke door comes crashing down, nylon rope broke. where can I get parts and how to fix it
  • SShipley Mar 10, 2009
    I've replaced the nylon ropes on both sides, but now door does not 'latch' closed: pops open about 1 inch. Door stays open at whatever point I put it at, so it seems the tension is right, door just won't latch.
  • 7 Answers
Pick up some nylon rope (same diameter or slightly larger) at any home store such as Home Depot, Lowes etc.. Need to attach the original plastic ends to your new nylon rope as well as to the door spring and then re-install on the bottom side of the door. Hopefully the other rope for the door assist is still intact so you can use that side as a guide as to how to route it around the pulley. Make sure that you lube the new rope up with some Vaseline etc. My door was squeaking very bad. Seems that the rope dries out over time which could have possibly caused your to snap. Pretty bad when your $1200 dishwasher door uses a length of small diameter rope to keep your door loaded with sensitive electronic boards from crashing to the floor!!!
Posted on Mar 05, 2009
  • KitchenAid Master
  • 19,396 Answers
Why does my dishwasher door fall freely when opened?
There are springs and pulleys that assist the door. They use a nylon rope that is very thin to connect the pulleys door and springs. The rope is most likely broken.
Jan 10, 2016 | Dishwashers
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
Left rear window went down and won't go up
Posted this earlier...similar problem..
First do you hear it trying to work, is it like a "clack, clack, clack" sound? or you hear the motor running smoothly? You will need to remove the door panel and take a look behind the plastic water seal to see whats going on, it is either going to be the regulator ( part the motor is attached to...cable broke)/damaged or more likely the nylon bushings inside the motor itself, they run like 10 bucks on Amazon. If you take the motor out of the regulator assembly be careful not to let the cable system come apart/unwind( use nylon ties while motor is out to hold in place). The motor itself is straight forward open/replace worn/falling apart nylon bushings/relube/reassemble. The tricky part is not screwing up the regulator assembly...depends on your skills.
Mar 18, 2013 | 1999 Mercury Mountaineer
Door spring rope broke on door , door falls when opened like to fix it need part and diagram of unit - enter the correct model number: SHE43P05UC in the search box on the right side, select which dishwasher you have from the results list. Click on the number of the part you need, it should show the manuf. par number on bottom.
or go to and check there.
Once you get the manufacturer's part numbers - go to - they have pictures of most parts.
First Choice Appliance, Sacramento
Jul 06, 2012 | Bosch Dishwashers
I need to replace pull rope that broke, how do I do this?
You can buy abaca fiber or nylon rope of the same length and size if you can't get an original one. Use the original handle bar for pulling. Tie one end of the rope at the center of the bar handle. Thanks for asking FixYa Customer Support.
Jun 14, 2011 | Honda Pressure Washer PSI 3000
The door to my dishwasher opens too easy now. Like it falls down too fast. what can I do to fix it?
A spring or a rope broke that holds the door...they are on the sides of the door to help support it..
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
May 12, 2011 | Dishwashers
Starter rope broke, how do I know what to order?
U really don't need to order anything.
Go to the hardware store and find some braded nylon line the same size as the old rope. Take a look around on this site, someone will tell u how to fix it.
Jul 17, 2010 | Ryobi Cultivator
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
May 11, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 | Dishwashers
Door drops -- no spring action
there are two nylon ropes that hook the door hinges to the door springs on the left and right side of the dishwasher.usually with time of rope breaks and the door stars to fall fix this pull the unit out and look for the broken rope on both sides of unit at the botom.the new ropes comes in a kit and are abt $ contains two ropes and new wheel assly.u dont realyy have 2 chge wheels unless they are broken.but chg both get rid of that squeeky noise aplly some bearing grease on the rollers over which the rope slides.that will take care of it.
Aug 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
475 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
