Question about Sony VPH-G90U Remanufactured CRT Graphics Projector (VPH G90U, VPHG90U, VPH-G90, VPH G90, VPHG90) Multimedia Projector
Red gun is shimmering on my sony g90
When you look into the red gun you can see a shimmer or fuzzynes going on and the image on a test pattern looks like its slightly out of focus , but when you put a signal onto it either composite or rgb the red goes way out of focus and the shimmering goes crazy like the signal path is going across high voltage of some sort thanks for any help.
techman
  • 3130 Answers
SOURCE: Picture - Flickers/Shimmers
Definatly has a problem it sounds like my freind. Could be a problem with the abl circuit, the picture tube or a voltage regulation problem. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 23, 2006
premtech
  • 934 Answers
SOURCE: Philips 42" Plasma
It's likely the upper Y-module but both the upper and lower could be having problems - just nothing noticeable in the lower half of the screen as yet, is my guess..
This is not a job for a layman and you'll need some fairly sophisticated equipment to troubleshoot the boards, not to mention being able to read schematics and understand waveforms. Hence, my best advice would be to take it in to a reputable shop and have it estimated...
If you need some help locating a shop near you try the NESDA locator - http://www.nesda.com/locator/state_search.php
Bill
Posted on Nov 11, 2007
SOURCE: Faint red lines in a curved arch like pattern
To access the focus block with the screen controls, remove the 2 plugs under the speaker grille. There is a philips head screw under each plug. Remove both screws. the speaker grill is now free. Pull the bottom forward and the grille will come off. The top is just held by tabs behind the screen bezel. Be careful as there is wiring to the grille for video input 2 and the front panel controls. There is a piece of fiberboard held on by 4 screws in the center which was formerly covered by the grille. Remove the screws and the panel and the focus block is right there. Each color is labeled for both screen level and focus. Adjust the screen control of the color producing the lines until the lines just disappear.
Posted on Mar 31, 2008
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
Posted on Jun 19, 2008
geemarie
  • 876 Answers
SOURCE: sony triinitron tv out of focus
Please go to this site for an answer:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C88962&fes=true&mdl=KV36FS120
This is information specifically for your television.
Good Luck to You!
Posted on Aug 16, 2008
Tv has a pink/magenta shimmering when the tv screen has a light coloured backgroung
Shimmering can be caused by a number of things.
The first that springs to mind is electromagnetic interference. Speakers, amplifiers, florescent lights in close proximity can cause this. I even saw a TV that had been fixed to a wall adjoining the next door neighbours who had put his TV in exactly the same position and the interference passed through the wall.
Try moving the TV location away from all sources of interference (including Cable boxes, Video recorders, etc.) Does the problem change or go away?
Is the TV grounded properly? Interference needs to be siphoned off to a ground. if you put your hand around the cable that feeds the TV a video signal does the problem change or reduce?
Another issue may be some form of video post-processing going on causing the shimmering. Some forms of image smoothing software built into the TV can cause this. So try shutting down any features on the TV, does the problem go away?
On a big TV that is fed a low resolution video stream you will always see what the industry calls "artefacts". These are distortions caused by the transport compression of the video signal. there is no way around these except for receiving a better resolution picture stream.
Mar 13, 2015 | Panasonic TCP42C1 Plasma TV
Samsung monitor shimmer
Hello try to upgade the graphic driver with this tool:
http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
I sometimes help. But the screen/ or cable could have a fault.
Good luck
Nov 01, 2012 | Samsung SyncMaster 245BW LCD Monitor
I want to buy a revlon limited edition nail color
If you are looking for the 2012 Revlon bright nail color line and it is the #240 Amethyst - Bright Purple Shimmer, then you can find it on eBay at this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280945606340
If not, OPI has a great bright purple shimmer color and is an even better polish in my opinion if you can't find the one your are looking for. Here is a link to an eBay seller where you can see a great photo of it, but I think you can still find it in stores too.
http://www.ebay.com/itm/NEW-OPI-Nail-Polish-Lacquer-Purple-With-A-Purpose-NL-B30-Bright-Shimmer-0-5oz-/150806129944?pt=LH_DefaultDomain_0&hash=item231cbeed18
Jul 06, 2012 | Health & Beauty
Shimmering
bad motor mounts or transmition mount
Jun 05, 2012 | 1999 Ford Ranger SuperCab
PHONE DROPPED. SCREEN IMAGES SHIMMER AT TIMES, OTHER TIMES OK
When the phone dropped, the flex that connect the screen to the main board might have been disconnected partially, if the screen does not look disfigured or have any crack then it is the flex that is causing the screen shimmers at times.
The solution to that is to remove the battery cover, the battery and the sim, then unscrew the phone to dismantle it, after doing that, carefully locate the flex and replace it with a new one or sit it properly.
After doing this, your phone should be in good shape once again.
Take care and good luck
Oct 21, 2010 | Sony Ericsson Z300a Cellular Phone
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Oct 23, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony VPH-G90U Remanufactured CRT Graphics Projector (VPH G90U, VPHG90U, VPH-G90, VPH G90, VPHG90) Multimedia Projector Logo
76 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
