Question about Sanyo Microwave Ovens
Light bulb replacement for sanyo ems3553 microwave oven
I need to replace the light bulb in my sanyo microwave oven model ems3553
  • Sanyo Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
How do I replace the bulb on a Sanyo EMD9550 combination microwave?
Attached link is to a youtube video for a whirlpool microwave. It may give you enough information to replace the lamp on your microwave. Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Aug 16, 2014 | Microwave Ovens
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Nov 16, 2009 | Sanyo Microwave Ovens
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Bulb gone in microwave oven compartment
Most models have a slide plat that covers the lamp. Other require you to remove approximately four screws and slide the entire panel out. Your owners manual will sometimes tell you how to replace a lamp for a microwave cabinet.
Jan 06, 2009 | Sanyo Microwave Ovens
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
How do I replace the oven lamp in a Sanyo EM-G471?
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
While your exact manual may not be online, there are several Sanyo manuals here, and one may be close enough to help.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
There may be a panel on the bottom covering the light(s), too.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 27, 2008 | Sanyo Microwave Ovens
Loose Light?
MOST MICROWAVE OVENS TODAY HAVE TO HAVE THE OUTER SLEEVE REMOVED TO ACCESS THE SIGHT BULB.
THIS IS DONE BY REMOVING ALL THE SCREWS ALONG THE BACK EDGE OF THE SLEEVE AND PULLING UP AND
BACKWARDS ON THE SLEEVE. SOMETIMES THE BULB ISN'T LOOSE BUT THE FILAMENT IS DANGLING IN THE LIGHT BULB AND OCCASIONALLY MAKES CONTACT WHEN IT IS BUMPED. THE BULB WOULD NEED REPLACED.
Mar 28, 2008 | Sanyo EM-Z2000S Microwave Oven
Light out
if there is a small cover on the side of the unit then the bulb will be under there if non you will have to remove the entire cover from the unit if you are not qaulified to do this then you need to take it to a repairer
cheers grant
Jan 14, 2008 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
300 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
