Question about Philips GoGear SA3125/37 MP3 Player
Pc drivars not pound. philips(gogear) not played.
  • 8,596 Answers
You have to load the installation software BEFORE you plug the Go Gear into the computer, or else Windows will try to load its own useless drivers first. If you have lost the installation CD, you can get the installation software from Philips website.
Posted on Mar 07, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I cant play videos
Make sure you have used the gogear media convertor that is required to convert the video files to the format required for the gogear.
Please log on tothe philip gogoear site to download the media software to be installed to your PC to tbe converted and loaded to your gogear.
Jan 08, 2011 | Philips GoGear ViBE Digital Media Player
GoGear Media engine error! DRM License using Vista
my phillips gogear mp3 os saying i have no media engine and a drm liecince
Sep 17, 2009 | Philips GOGEAR SA6045 MP3 Player
How To Add Videos to my gogear mp3 player
Go to www.usasupport.philips.com - download the latest version of the Philips (Arcsoft) Media Converter
Jan 14, 2009 | Philips GOGEAR SA6045 MP3 Player
Gogear 8gb
The HDD1830 is not Mac compatible. The database file has probably been deleted or corrupted. The player doesn't scan the hard disk on start-up, it only read the database file. Anything it doesn't read from the database file is ignored.
You will need to restore the player with the Philips Device Manager, and re-load your tracks.
Jun 20, 2008 | Philips GoGear HDD1830 MP3 Player
Stubborn refusal!
Go ahead and open the Philips Device Manager and run the "Repair" function. Warning: this will delete all files off your mp3 player.
1) Connect GoGear to computer
2) Open Philips Device Manager (Start --> All Programs --> Philips in Windows XP if no shortcut on desktop)
3) Click on the Repair tab - see if there is a msg that says something like "to repair your player, connect GoGear to computer while holding the volume + button"
4)IMPORTANT: Disconnect the GoGear from the USB cable, turn the GoGear OFF, and then press and hold the volume + button; then, connect your GoGear to PC while still holding the volume + button (VERY IMPORTANT: this process will fix your player, but it will also delete all music and images you have stored on the GoGear) - do not let go of the Volume + button until a pop-up comes up saying that your player is being repaired
After the repair process is complete, your player should work fine - you will have to re-download all files to the GoGear.
Mar 15, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear mp3
Sounds like the files are DRM copy protected.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under "protected". Check your non-playing tracks are listed as No, under "protected".
The HDD1830 is not compatible with protected files, although your PC will play them ok.
Feb 29, 2008 | Philips GoGear HDD1830 MP3 Player
Resetting
To reset, press volume+ and play at the same time until the player shuts off.
Then:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Sep 11, 2007 | Philips GoGear HDD1830 MP3 Player
My philips 30gb wont play my songs!!!
-Tha Mp3 Doctor
Jun 20, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
98 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
