Question about Parasound HCA-1000A 2-Channel Amplifier
Parasound HCA-3500 temp alarm
I bought a used Parasound HCA-3500 and have had an intermitent problem since the first day. the "TEMP" alarm will come on almost immediately for the right channel which shuts that channel down. This does not always occurr and sometimes I can just turn the power button off and then back on and it is fine with the alarm never coming back for that listening period. Any solutions?
Thanks,
Mike
5 Suggested Answers
shivam4529
  • 150 Answers
SOURCE: overload led on 2 channels
i think your prob is not simple if anybody tell u do this or tat don't do it because i have a same prob but my fault is try myself and it becomes more disable and father beaten me
so acc to my opinion go to the expert and where u buy this he normaled your problem don't worry i do the same thing
and u again enjoy
WARNING:
DO NOT OPEN YOURSELF
IF U HAVE TRUST ON ME MY ID IS
mango4529@radiffmail.com
Posted on Nov 20, 2007
bmf4069
  • 6 Answers
SOURCE: Problems Overload Protection Being Invoked - Parasound HCA-2003
You may want to get an Ohm meter and check between the outputs of the amp yourself. 0 ohms means a short somewhere.
You should also check to se when you're hooking the speaker wires in that they're not frayed and touching hot to ground or hot to the amp casing. hope that helps!
Posted on Nov 19, 2008
  • 504 Answers
SOURCE: why does my parasound a21 shuts off intermitently during play
check for heating is device geting very heat if yes then you chould check heatshink
Posted on May 19, 2012
Grubhead
  • 5390 Answers
SOURCE: how to fix 2 fuses on the left of the amp? the right side work well.
Fuses only blow if there is an overload somewhere. The most likely cause being a transitor that has shorted out. Easy to spot with a multi-meter on the ohms setting. As it will be liked you have touched the test leads together!
Posted on Oct 30, 2012
How to fix 2 fuses on the left of the amp? the right side work well.
Aug 21, 2012 | Parasound HCA-1000A 2-Channel Amplifier
Why does my parasound a21 shuts off intermitently during play
May 18, 2012 | Parasound A 21 Amplifier
Amplifier wont turn on. the orange ac light is on but nothing else
Check internal AC fuse. If intact, amplifier may be in protect mode due to fault.
Oct 27, 2011 | Parasound HCA-1000A 2-Channel Amplifier
I have an overload indicator on channel 2. I opened the lid and swapped the channel 2 module with the channel 5 module and the overload light followed the card and showed up on channel 5. Parasound said...
I believe that the output transistors may be bad. Without seeing the actual card, there is no way to tell. If the parts are under warranty, request a replacement board. If I remember correctly, the board is the field replaceable unit (smallest orderable part) anyway. If not, you will need instruction from Parasound about what to do next.
Dan
Sep 03, 2010 | Parasound HCA-2205AT 5-Channel Amplifier
Smell like a electrical smell ocassionaly coming
Its probably getting hot so you might smell the components heating up. I would try to if possible clear up some space and try cleaning the unit with a air can. Try to get dust that builds up over time
Sep 09, 2009 | Parasound HCA-750A 2-Channel Amplifier
Nov 18, 2008 | Audio Players & Recorders
FACTORY ALARM GOES OFF INTERMITTINGLY. INSIDE GARAGE, AND GARAGE ALARM NOT TRIGGERED. HAD TO REMOVE FUSE TO STOP SOUNDING LAST NITE. 2007 LIMITED
You ,most likely have a defective door switch or anti-tamper switch, both are the same part, replace the switch.
Aug 29, 2008 | Hyundai Santa Fe Cars & Trucks
Noisy transformer
Normally, power transformers don't hum loudly unless there is a problem in power supply circuit. If all seems normally operational, the problem may be simply anchor screws that hold transformer to frame may be loose. Try tightening them
Apr 29, 2008 | Parasound HCA-855A 5-Channel Amplifier
Parasound HCA-1000A 2-Channel Amplifier Logo
298 people viewed this question
Top Parasound Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Gil Shultz
Are you a Parasound Audio Player and Recorder Expert? Answer questions, earn points and help others
