When you turn the key it does nothing at all.have to turn it back and forth several times for it to start
SOURCE: car won't start when I first turn the key
might not be getting enough fuel to the motor. try replacing the fuel filter
SOURCE: I turn the key and nothing happens, not even a
Bad connection or bad starter which can be checked at Autozone for free. which is why jumping doesnt help.check battery connections, and wiring at the starter.
SOURCE: car will not start,battery good.Turn key in the
try jumpin it to double check its not the battery. if not check spark plugs. if that doesnt work then id safely say you'll either need a new starting motor or a fuel pump
SOURCE: 1989 mitsu Galant 62,000 original miles. Sometimes
It could be a loose battery cable to starter connection or loose ground wire or corrosion on the battery cables or wires. I would check all connections and wires for looseness, wear and corrosion and tighten or replace as needed,
SOURCE: I ran out of gas and now my car wont start
ON your fuel rail under your hood is a pressure release valve. It looks like your tire inflation valve. It may have a black cap. remove cap, turn on key, then turn off. press the valve to release the fuel pressure. do this a few time and it will bleed your system off excess air. sounds like you have a vapor lock.
