Question about Foxconn 661FX4MR-ES Motherboard
Clarification about my foxconn bios checksum error
My pc boot but it display bios checksum error; no keyboard present; no keyboard detected and insert system disk on floppy drive. what is nedd to be done? any suggestion? i think the flash bios had a problem, do i need to flash it?
  • 83 Answers
Try to change cmos battery...
or
flash BIOS
download bios from bellow link
and pls refer the manual.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000004
thnaks
if ur problem solve so pls rate me..
bye
Posted on Mar 05, 2009
Tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 | Computers & Internet
Dell m90 beeping codes
Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Mar 03, 2013 | Dell Computers & Internet
MOTHERBOARD PROBLEM HELP....THIS IS MY 3RD POST ABOUT THE
You have a corrupted bios file or files. This is what the checksum means. You need to download the correct bios onto a floppy disk. That floppy disk needs to formatted as a system / startup disk BEFORE you copy the bios files to it. Then put the floppy into your floppy drive, turn the pc on and try to get into the bios screens. If the keyboard error is preventing this, go to the mainboard manufacturers website and check the correct manual for the board looking for the procedure to recover from a bios failure. If this board if no older then 5 yrs, it should have this feature. Follow the recovery procedure to rewrite your bios. When that is fixed, undertake the bios update procedure. ONLY do this if you fully understand and accept the risks otherwise, take it to your local professional. If your board does not have the recovery feature, replace it !!unless you are able to replace the CMOS chip with one which has the correct bios burnt onto it. As most modern boards have CMOS chips glued and soldered to the board, this may not be an option..If the bios chip is socketed, contact your local computer shop, or the boards manufacturer to request a replacement. Your issues all arise from your bios issues so fix that and all should be well..
Dec 12, 2009 | Foxconn WinFast K7S741MG Motherboard for...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Will not boot up. Get Bios Rom Checksum error, Keyboard error or no keyboard present. Manually shut down and turned on literally 30 times this morning before it would boot up. Then after a couple of hours...
most times a checksum error refers to the cmos battery. you may want to replace the battery and see if that helps. However this can also be a symptom caused by a bad power supply or a faulty board. Make sure you check your motherboard's capacitors for swelling or leaking.
hope this helps.
Dec 10, 2009 | HP Pavilion m7480n (882780389410) PC...
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Dec 12, 2008 | Intel D102GGC2 Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Dell dimension 3100 when turned on bleeps and no display on monitor
It depends on how many times it bleeps.
More info here: http://www.bioscentral.com/postcodes/dellbios.htm
Oct 28, 2008 | Computers & Internet
this is a common problem wirth asus motherboards the only thing is to re set the bios to do this romove the power plug from pc wait for 30 second - 1 minute for the static to be removed from board then find the bios battery and remove this then find the jumper that says clr cymos or bios then place the jumper on the opposite two then press on button then place jumper bace to orraginal possition then place the power cord back to tower psu then reboot pc then all will be fine replace battery in the holder enter bios then hunt for all relevent thing like first boot should be hdd then cdrom then floppy drive this is only if you have got one.
to set-up bios properly please e-mail me with your motherboard details and I'll e-mail you back with a list of things you should do to get the bios back to good working order.
Aug 25, 2008 | ASUS A8N-E Motherboard
Foxconn 661FX4MR-ES Motherboard Logo
991 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
