Question about Panasonic NN-A811A Convection/Microwave Oven
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
  • Panasonic Master
  • 9,098 Answers
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Posted on Mar 06, 2009
Lost instruction book for panasonic inverter slimline combi
Check THIS LINK or try with your right model.
I hope this helps; remember to rating this free answer and leave us a testimonial comment.
Oct 13, 2011 | Microwave Ovens
I have been given a Panasonic combi inverter microwave/oven. There are no user instructions can you help me to find a manual?
here is the link to the instruction manual of your device from panasonic:--
click the link directly:--
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/model.NN-H275BF
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 06, 2009 | Panasonic Microwave Ovens
I have a panasonic slimline combi NN A554W which was not cheap. worked well until this week. put timer on to microwave and it goes down 5 secs then turns of. A clicking noise can be heard. Clock working....
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Oct 06, 2009 | Panasonic Microwave Ovens
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-SD376S
Desperately need
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-K593MF. please help
Jul 20, 2009 | Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
The bulb is not working in my Panasonic NN-A554W inverter slimline combi oven and I do not know the size/number to obtain a replacement. I know you are supposed to get in an engineer but that is a bit...
It's a T170 type bulb (should be very common at a grocery store or hardware store) rated at 240 volt, either 20 or 25 watt is okay, and if you order it as a spare online, it may come with the 90-degree bracket.
You can see a good photo and detailed specifications here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Panasonic NN-A811A Convection/Microwave Oven Logo
1,987 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
