Question about GE 106591 Coffee Maker
Error keeps popping up
No matter what button is hit the coffee maker will only say error on screen
  • 8,596 Answers
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Posted on Mar 09, 2009
  • Corey Knoettgen
    Corey Knoettgen Mar 09, 2009
    That came out all worng:
    problem: prog (24) was pressed before clock time was set
    solution: Set clock time, then set the program
    problem: auto (23) was pressed while no program was stored
    soultion: Set the program first.
    problem: TSB was pressed (25) before brew cycle was complete
    solution: Wait until brew cycle is complete and 2 beeps sound
    -Tha Mp3 Doctor
My jura impressa 9 keep saying not enough coffee no matter what i do
bad sensor, you can try blowing area clean with compressed air, pres the helpful button
Jan 30, 2016 | Jura ENA 3 Automatic Coffee Center - Black
It keeps cutting off, have to keep hitting power button after on for awhile
Inside the coffee maker there is a small screen filter that must be be half plugged you have to take the machine apart to clean it, it is hard enough job to fix it.
Mar 27, 2015 | Keurig Elite B40 Coffee Maker
Plumbed coffee system has blank screen
Strange. If the onboard computer has stopped working, first thing to try is a reboot -- the trick being, right now you can't shut it off. No matter. If the plug is inaccessible, go to your breaker box and shut it off at the breaker. Wait a minute, turn it back on, and see if it boots up correctly after that.
Feb 22, 2015 | Miele Coffee System
I do not know how to set the timer on the B60
OK - here you go:
1. Hit your menu button
2. The first prompt is to set the clock, if you do not need to reset your time - then just hit the menu button again.
3. Your next prompt is for auto off, this'll set it to cut off after a specified time. However, you also want it to come on at a specified time right?
4. Hit menu again. This takes you to auto on/auto off (a.k.a. your timer). From here simply use the buttons to the right or left of the menu button to set the time (watch out for am/pm).
5. Flip thru the last 2 menu options of brew temp & brew size. Make any changes you want to there.
6. Finally you'll end up back on the home screen - if you set the timer, then you will see "ONOFFTIMESET" on the home screen.
Jul 12, 2011 | Keurig B60 Coffee Maker
Menu screen keeps popping up instead of "ready to
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101;;'
Jun 11, 2011 | Keurig Special Edition B60 Coffee Maker
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Our Keurig coffee maker does not work properly. When we try to use it and select which amount to make (from the free small buttons), it goes down the list fo selection, such as the temperature of the...
It sounds like your menu button (Black) is being hit first. Is the button stuck down or has anything been spilled on the control area. The buttons may be shorting out and being triggered inadvertently.
Feb 06, 2010 | Keurig B60 Coffee Maker
It only makes one size coffee. When you hit the
my machine is the antony worrall thompson espresso coffee maker breville
Nov 22, 2009 | Keurig Elite B40 Coffee Maker
Coffee maker hit or miss on dispensing the coffee.
You have a short , or bad connection in the lid switch. Probally cheeper to buy a new coffee pot than fit it????
Jan 30, 2009 | Keurig Elite B40 Coffee Maker
GE 106591 Coffee Maker Logo
241 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
