Question about PIONEERPOS M55E25R30P PC Notebook
How do I fit wireless card into medion mim2120 laptop?
Friend has 2 year old Medion laptop & now wants to use WIFE facility. Apparently this is an upgrade (not supplied) & I was told a '56K Modem card for the Medion mim2120 will work. Now have this but it has no info supplied. Need to know where it is fitted into laptop, whether it needs hardware driver download & even if aerials are prewired. If card is not correct what do I have to get? Appreciate any help.
    President:
  • 2,992 Answers
I assume you mean "wi-fi" wireless access. The easy solution if wireless networking wasn't built in is to use a USB wireless adapter that simply plugs in to any USB connector on the laptop. These adaptors are available at retailers where you can buy computers as well as from many online sources. The adapter will come with any software and installation instructions you need.
Please take a moment to give this solution a fixya rating if it has been what you needed, and thanks for asking here!
Posted on Mar 05, 2009
My medion 96640 video card has collapsed. need a new video card
I think its the whole motherboard to get the card because you cannot buy them.
An if they can be sourced would be talking about 150 or 200 an with fitting about 240 so not really worth it sell it as spares unless u can get a faulty 1 off ebay with broken screen or something like that
Mar 11, 2010 | Computers & Internet
I have Medion 2310 notebook, and there is apparently a switch to enable wireless connection
Yah...you can use this switch to ON your wireless (wi-fi) adapter!
any problem with wireless ? tell me...! :)
Jan 02, 2010 | Medion md40298 Notebook
Have brought a wireless card to go inside the laptop. Just not sure where it goes inside! There is a power supply cable and a long slot, but this is a tiny card and is far smaller than the slot, can it...
Must admit I am not familiar with this brand and a bit of googling suggests that this model already has built in wireless. However, some forum postings suggested that it in fact doesn't and that the required mini wireless card (which may be what you have bought) connects to the mainboard via a removable cover on the underside of the laptop.
Never come across that before - I have always had PCMCIA wireless cards which are about the size of a fat credit card, and fit in the slot I think you are describing. Sorry, not much to go on. I suggest that you ask Medion Support:
http://www.medion.co.uk/service/?ukshop
Sep 09, 2009 | Computers & Internet
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version 1.5.0.5 of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
http://www1.medion.de/downloads/?op=search&lang=au&type=TEXT&Param=
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
Laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
Aug 18, 2008 | Computers & Internet
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
Aug 18, 2008 | Medion MD-40954 Notebook
Updates not installing
I have found, depending on the update, that downloading them manually to your desktop, then installing them from there usally does the trick. Just write down the KB number of the update and go to http://www.microsoft.com/downloads/Search.aspx and download.
Mar 05, 2008 | Medion MD-40954 Notebook
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Medion MIM2120 laptop
press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Dec 04, 2007 | Medion md40298 Notebook
Computers & Internet Logo
304 people viewed this question
Top PIONEERPOS Computers & Internet Experts
David Payne
David Payne
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
