Question about SanDisk Sansa e250 MP3 Player
My Sansa Express shown in my computer as removable drive but it doesn't respond and after unplugging it splash and go die.... Any one , Thank U
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Posted on Apr 15, 2009
My Sansa e200 series is stuck on the splash screen and would not response on any or cannot be recognized by computer. Please assist
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
Jun 27, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa Express MP3 player does not show up on my computer as "Sansa Express" but is shown as Removable Disk (K:). Is this right
Normally your Sansa Express would show up as "Sansa Express", which would indicate that it is in MTP mode. The Sansa Express doesn't supply a menu option to switch to MSC mode, which would cause it to show up as a "removable disk". Apparently your Sansa Express has somehow switched to MSC mode. MSC mode is necessary for upgrading firmware, in which case it's called "recovery mode", and it's possible that some combination of key presses (usually involving holding down the power/hold button) put it into this mode.
If you double-click on "removable disk (K:)", do you see a Music folder? If so, is there anything in the Music folder?
Feb 11, 2010 | SanDisk Sansa MP3 Player
Sansa express player does not respond, looks like it's off (screen is black) but when connecting headphones it makes the sound as if a song is paused, computer can't see it so its impossible to format. ...
Try and do what is called a Power Reset. To power reset the device, simultaneously press and hold the center and volume up button, while connecting it to the PC.
If this fails, charge the device for at least two and a half hours. The computer should not go into sleep or hibernation state while charging.
Then you may want to update the players firmware by downloading and installing the Sansa Firmware Updater.
Jan 30, 2010 | SanDisk Sansa MP3 Player
Dear sir i am using sansa express 1gb .its not working at all.when i switch on the player it shows "sansa" for 2 min ,then it disappears.after that i wnt be able to open it.but my computer is dtecting when...
There is online support for Sansa Express. When searching for Answers on the topic "express" it gives next list:
http://kb.sandisk.com/app/answers/list/kw/express/r_id/101834
Going to item 13 "Sansa player not recognized by the computer":
http://kb.sandisk.com/app/answers/detail/a_id/42
When the player is brand new, click on the link in the opened page in the page top or use next direct link:
http://kb.sandisk.com/app/answers/detail/a_id/42#brandnew
Else follow up the instructions as described in item 13.
Sansa Express user guide
If more help is needed just post a comment.
Sep 24, 2009 | SanDisk Sansa MP3 Player
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
My Sansa Sandisk express flash drive mp3 player wont come on
firstly you should only remove a usb device "correctly" otherwise problems can occur with device ,pc or both.....when usb device connected there is a small icon on taskbar with a green arrow on it....to renove device right click this icon and choose apprpriate device to STOP....there is a reset button that you can press to reset settings...look for a 1mm hole and put a pin into it and push...goos luck
Nov 16, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Can't access on the computer and doesn't turn on when disconnected
I downloaded and reinstalled the latest version of media player form windows. problem solved. thanks anyway.
Trent
Jul 25, 2008 | SanDisk Sansa MP3 Player
What to do if you deleted everything on a sansa e250 MP3 player
Connect the sansa to your comp.. it will be shown as a drive right?Well just right-clickand click format...Thats all..
Nov 07, 2007 | SanDisk Sansa e200 MP3 Player
Sansa mp3 player
If the player is in MTP/Autodetect you can just unplug the player from the computer. You can check this by going to the My Computer window and see if the player is listed and if it has a drive letter before it, if it dont have a drive letter then it means the player is in MTP/Autodetect you can just unplug the player from the computer.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
