Question about Acer Aspire 3680 Laptop
Backlights started reducing all on its own untill totally dark.
I borrowed my Zinox computer to a friend and he returns the computer it was working good but all of a sudden i saw the screen lights reduced till it was absolutely dark. I figured out that i can see through it with the help of a strong touch light. I once restarted the system, after the processor Pentium M shows up, I press the alt and insert keys, and the light returns but after about 2 hours of browsing the lights reduced again till was completely dark. I still have to use a touch light to view the contents on the screen. Also i've formatted it several times including changing to Ubuntu linox from XP, but it's still the same, i still have to use the battery.
  • Acer Master
  • 4,806 Answers
Hi there.
The problem you describe is a failing or faulty inverter board, this is located just under the screen behind the plastic surround.
This is a common problem across all makes and models of laptops and some LCD monitors.
If your machine is covered by the manufacturers warranty, take advantage and send the laptop to be repaired free.
If your out of warranty you will have to take the laptop to a PC technician for repair, it should not cost that much for that type of repair.
Good luck and thanks for using FixYa!!
Posted on Mar 05, 2009
What's my next step in diagnosing my Vizio LCD TV picture issue?
Hi Tim,
If all the boards you replaced were good and working, the only thing remains is the panel if the backlights are on. Please see that the LVDS cable is carrying voltage to the Tcon board.
Good luck.
May 10, 2016 | Vizio E701i-A3
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
Wath can i do? i cldnt hear any souud 4rm my zinox laptop imidiately after formarting.
Buy a driver magician full version installation disk and install it to your computer. After installing it, run the program and for sure, driver magician will automatically detect the driver that your loptop need for it's sound to work properly. Select it and driver magician will download it for you . Install the downloaded loptop sound driver and after you reboot you loptop you shoul be able to hear a sound again from your loptop as if it's driver has not been deleted. Have a nice day my friend, hope this would help you.
Aug 17, 2011 | Computers & Internet
This problemis with Zinox Smart model, (window could not start becuase the following file is missing \window\system32\config\system)
your computer registry is corrupt. rename the registry file from system to system.old then copy the system file from the repair folder and paste it into the config folder. be aware that some of your accessories will not work until you reinstall them. the only other way to resolve this issue is to reinstall windows.
Apr 14, 2011 | Computers & Internet
My dell inspiron 546's monitor has gone dark the screen is still visable but really dark how do i make it bright again i already tried the brightness and contrast on monitor
It might be that the CFL lighting tubes on your monitor have failed, in which case they need to be replaced. Borrow a screen to try on your computer to test if it is in actual fact the your screen that is faulty. This is normally fixed by a computer technician! If it is under warranty return it!
Nov 27, 2010 | Dell Inspiron 546 MT Desktop Computer
Laptop screen doesnt turn on
when you bootup all the way put a flashlight point it at the screen.
Do you see anything in the background?
Some people see shadows.
Basically it looks like the backlights do not work.
Sometimes inverters can go in which all you need to do is buy a new inverter and install it.
Let me know either way
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Dark screen?
press 2nd, hold the down key until the screen lightens up.
May 07, 2008 | Texas Instruments TI-85 Calculator
Acer Aspire 3680 Laptop Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
