Got an Indesit wil103 washing machine thats not rinsing properly. It goes through all the programme apparently correctly but theres lots of soap left after the final spin. Sometimes the clothes come out a bit smelly too! I always have to rinse more than once Paula
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Try to power off you unit for about 5-10 minutes then plug it back in. Did the technician touch the control board?
Oct 22, 2008 | Indesit W 123 Front Load Washer
Dishwasher leaves baked on soap scum on al dishes and everything ....even on the dishwasher ...tried all kinds of soap and rinse aid...nothing works...cleaned entire washer out cleaned all filters...
I imagine you've already checked that you're using the correct amount of detergent for the wash programme, and that you're washing the correct quantity of dishes for the wash programme, though if not, try that first!
Is the dishwasher heating the water to the correct temperature? If it's not rinsing at a hot enough temperature, the detergent may leave a residue. In that case, your dishes would probably also be less than entirely clean; they could be slightly greasy when removed from the machine.
Another possibility is that insufficient water is supplied to the dishwasher, so it might be worth checking the tap that lets water through the hose and into the machine. Does the tap turn on fully? Does it turn off properly?
The other thing that might be worth trying is an empty wash: put the machine through a wash programme WITH detergent but WITHOUT dishes, at the programme with the highest temperature. Is all the soap scum washed away? Or is there still a residue inside the machine? If the empty wash works, you probably need to give your machine a maintenance wash once a month or so. This is often the case if you usually wash your dishes a few at a time on a short programme.
I hope some of that helps. Good luck!
Oct 09, 2010 | Bosch Dishwashers
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Indesit WIDL126UK that never wants to stop!
did you ever get to the root of the problem >}?
mine is doing the same.
Sep 25, 2009 | Washing Machines
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Hi there where can i download an operation manual for an Indesit WIL103 washing machine thanks
In your browser bar type in---- indesit user manuals
In the drop down list click on------indesit- manuals-user guides-handbooks-indesit service
In the search box type in your model number, and down load instructions.
Plz rate my solution.
Jan 17, 2009 | Washing Machines
Washing macine indesit wil103
i need a intrution manual for my indesit wil103 washing machine
Jul 09, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine, wil103
from the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
Dec 19, 2007 | Washing Machines
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
