Question about Kitchen Ranges
Reference Vulcan Monterey Eye Level Cooker. Clock and timer stopped working, oven and hotplates work OK. Does clock require oiling/cleaning and how can clock be accessed or removed?
  • lmw134 Mar 05, 2009
    Thank you for advising that clock does not need oiling but needs testing. How can this be done and does the clock have to be removed, if so, how?
  • lmw134 Mar 06, 2009
    I am sorry that you could not answer my question. You gave be a telephone number - is that in USA and to speak to that party does that cost extra ? I reside in Australia.
    Thanks.
  • 564 Answers
You can call to this number. They provide you exact steps to fix this
Vulcan
3600 North Point Boulevard
Baltimore, MD 21222
Call 866-988-5226
Fax 800-444-0602
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Mar 05, 2009
  • Prem  Kumar
    Prem Kumar Mar 08, 2009
    Rheem Australia Head Office
    ADDRESS:
    1 Alan Street, Rydalmere NSW 2116
    PHONE:
    (02) 9684 9100
    FAX:
    (02) 9684 9184
  • Prem  Kumar
    Rheem Australia Regional Office Contact Details
      NEW SOUTH WALES
      Sydney:
      1 Alan Street,
      Rydalmere NSW 2116
      PH: (02) 9684 9281
      FAX: (02) 9684 9187
      Newcastle:
      PH: (02) 4961 3515
      FAX: (02) 4961 3117
      A.C.T
      Canberra:
      PH: (02) 9684 9281
      FAX: (02) 9684 9187
      VICTORIA
      Melbourne:
      PH: (03) 9212 8919
      FAX: (03) 9212 8940
      SOUTH AUSTRALIA
      Adelaide:
      PH: (08) 8343 0055
      FAX: (08) 8359 6004
      WESTERN AUSTRALIA
      Perth:
      PH: (08) 9351 4293
      FAX: (08) 9356 283
      TASMANIA
      Hobart:
      PH: 0439 411 319
      FAX: (03) 6248 4275
      QUEENSLAND
      Brisbane:
      PH: (07) 3213 0177
      FAX: (07) 3277 1852
      NORTHERN TERRITORY
      Northern Territory:
      PH: (08) 8947 0274
      FAX: (08) 8947 1944
      After Sales Service:
      PH: 131 031
      INTERNATIONAL
      Sydney:
      PH: +61(2) 9684 9338
      FAX: +61(2) 9684 9181
  • 19,396 Answers
Clocki does not need oiling, but it has a control assembly that may be faulty and must be tested.
  • 1 more comment
  • Ginko
    Ginko Mar 05, 2009
    New Vulcan Monterey ranges have electronics control, in that case that is the problem.
    If instead you have an older model, with analog timer, then the timer mechanism may be jammed with grease.
    In this case it does not need to be oiled, but instead to be removed from range and soaked in grase, then you can oil it back.
  • Ginko
    Ginko Mar 05, 2009
    If it need testing that is done using a Multimeter to identify faulty components.
    It will be useful if you can tell me your range model, or select from Vulcan website here.
  • Ginko
    Ginko Mar 06, 2009
    Sorry, here Vulcan Australia:
    Vulcan Water Heaters
    ADDRESS:
    PHONE:
    (02) 9684 9100
    FAX:
    (02) 9684 9184
    Click here to contact us using our Customer Enquiry Form
    See Contact Page Here.
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
For some reason my cooker keeps switching itself off, unless the timer is set to 12:01 it does this. It used to go off when the timer counted down to 8 mins, but this varies, and now it has a mind of its...
It sounds like you are setting a cooking time instead of setting the time of day. The oven wont work until a time of day is set. press the centre button (4x)until a red light flashes in the bottom right corner of the clock if you miss it keep pressing until you cycle through to the rh corner(note clock symbal) press + or - until you get to the right time leave for 12 secs then time locks in and your oven will work. the other flashing lites top left= cooking time bottom left =end time top right =timer function with no oven control. If this does not solve it the timer is faulty and requires replacing. good luck.
Oct 31, 2010 | Electrolux Insight EKC6049X Stainless...
The timer has gone on the cooker and I can't use the oven or the grill
Open and check for traces of dirt in the system due to insects. Clean the printed circuit board and check if the timer works. If not you will need to install a new one for using the timer. Hope the model uses the electronic type. If manual type try to clean and reset the clock action as a last resort.It might work with a good oiling, dirt cleaning using a good cleaner like WD40. hope you try this out. Good day
Aug 11, 2010 | Electrolux Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
