Question about Toshiba Tecra A6-EZ6411 (PTA63U-003003) PC Notebook
After recharging my is not working
Three green lights are there! but the screen is black???????
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Charging socket
You have to do this correctly or there's going to be a lot of smoke! The black wire is negative, the white positive and the green is ground. The 3-pin female XLR connector you refer to has the three pins where the charger plugs in. Position this connector to that when you look at it, the three pins form a V. The top two pins are directly across from each other, and the bottom pin is at the bottom of the V. The black wire goes to the top left pin, the white goes to the right top pin, and the green goes to the bottom of the V.
Nov 10, 2009 | Shoprider Sprinter 889B-4 Scooter by
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
Owners manual lost
I have some similar swimming pool lights that are rechargeable. If my light, green means that the battery is ready for use, orange means that the battery is getting low, and red means that you need to recharge. I would assume that this is the same for yours (because mine is very similar). Hope this helps.
Jul 12, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Ds lite green light is on but both screens are black and no sound
For GBA games the green light is meant to stay on. The orange light will stay on as long as its recharging. It will turn off when its fully recharged or when you unplug it
Apr 23, 2009 | Nintendo DS Lite Console
Installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Toshiba Tecra  A6-EZ6411 (PTA63U-003003) PC Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
