Question about Canon PIXMA MP150 All-In-One InkJet Printer
I cannot remove tne ink cartridge of my canon mp140 printer.the ribbon does not move.even if i pull it.. the ink get stucked
    President:
  • 566 Answers
For a tutorial (with images) on how to replace the ink cartriges, click on this link (CANON FAQs for your printer) :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15294&kbpage=yes#
Then, in the "Please enter your question..." textbox, type "replace ink cartriges".
Click on the link that says "How do I replace ink cartridge(s)?"
Posted on Aug 16, 2009
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
My canon mx410 printer won't turn on
I had this problem before, just open the cover, pull out the cartridges, it wont pull by itself, cause there is no power, so pull the wire!!!, remove the cartridges and turn the the power! it works!!!
Nov 13, 2011 | Canon Pixma MX410 All-In-One Printer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
CANON MP140 REPLACE WITH NEW IN BUT WILL NOT RECOGNISE THEM BUT I JUST WANT TO USE THE SCANNER BUT IT WONT LET ME AS IT IS DISPLAYING ERROR 5 MESSAGE
hi, first remove your ink cartridge; and clean inside the carriadge, install a new cartridge, and reset your ink counter use this link to reset the ink counter, http://www.fixya.com/support/r7066832-reset_canon_pixma_mp140 if my solution helps you please vote it thanks
Nov 30, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
CANT PUT INK CARTRIDGE IN CANON MP140
Aug 16, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
My canon mp140 shows E4
From CANON FAQs for your printer:
Issue: ERROR LED: E, 4
Solution: Press and hold Stop/Reset button for at least five seconds.
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I placed a re-filled ink cartridges in my canon mp140 printer and
Computer chips in cartridges must be reset before the printer will recognize them as full. If you paid a shop to refill your cartridges take them back and complain. The best places will test the refilled cartridge before giving it to you.
Please note durability of prints using cheap ink is usually very poor, and as a result the manufacturers ink is usually much the better choice.
Mar 05, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon mp140
Replace the ink cartridge or press OK
Jul 28, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
155 people viewed this question
old marine
old marine
