Question about ASUS K8V-MX Motherboard
Mother board is dead
No dislay but voltage section is ok, ram section is ok,north bridge section is ok other trouble shoot please help me
    Master:
  • 505 Answers
What happens with you turn it on anything i need a little more info please
Posted on Mar 09, 2009
Fuse 18 for dash lights keep blowing. Have replaced light switch and instrument cluster
If your fuse blows repeatedly, the circuit is drawing
too much current. Possible causes:
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
May 06, 2013 | Rotora 2003 DODGE RAM 1500 PICKUP...
System is running , fan cd room all are ok but no any display on monitor . What may be the problem?
hook up speakers to the mother board when testing see if you get any beep codes ram not seated properly will cause you to have no video. The beep codes will help you know the problem.
May 04, 2011 | Asrock P4I45GV R5 Motherboard
1. function of bios chip 2. function of north and south bridge chipset 3. cpu function
Hi there. Here is a brief description of those components found on the motherboard.
1. BIOS chip: This is known as Basic Input Output System and the chip contains the base instructions on how to boot the PC. All personalized settings can be configured in the BIOS such as CPU overclocking.
2. North Bridge: This component works with high speed hardware components such as RAM and PCI-E cards.
3.South Bridge: This component works with slower speed hardware components such as the hard drive and USB.
4. CPU: Central Processing Unit, this is basically the brain of a computer and this component is the one that does all calculating of data. So when you run an application, the CPU processes the data involving the application.
Please rate and comment, thank you.
Apr 16, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Find north and south bridge for asua maximus 2 mother board
I do not the north bridge of this motherboard is different from others. mainly ram ports and Graphics card pord is called north bridge. read it for more. ( click here )
May 24, 2009 | ASUS Maximus Formula Motherboard - 45nm...
4 pin plug 12volt on the motherboard.
pls you have to identify which area is short circuit, there for remove the 4 pin plug and power on. of power on ,it is telling your cpu section (VRM Circuit is short) it may faulty cap or transistor , bit I found more than 80% is shorted north bridge.
it was not fixed. but you have to test all coils to identify which section mos fets are short, remove the cpu to isolate north bridge , check vrm circuit,
images?q=tbn:and9gctvnhhmvqm60iuldruuri-bndxickpzhgxm7juwfsizc3gdj9_-4a
Aug 26, 2017 | Intel D945GTP Motherboard
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Oct 17, 2007 | E-Machines eMachines Desktop PC
Power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
Mar 12, 2007 | Sony STR-DE545 Receiver
ASUS K8V-MX Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
