Question about Tally T2250 Matrix Printer
How can i share tally 7.2 from server to client
Issue with time synchronizing(NTP) on layer 2 switch
I know this is probably not going to help you out but you did try going to Alcatel-Lucents web page and search through there or calling them at 800 995-2696? Good Luck! Sorry I couldn't be of some help
Mar 04, 2014 | Alcatel OmniSwitch 6850 (OS6850-48)
Tally erp 9 working slow
you have not mentioned the networking involved .?
how are the clients networked to the server ?
Are you using a switch or a hub ?
Are you using a fast ethernet connection 100 Mbs or 1000 mbs into server from a network switch ?
How fast ? 10 mbs will cause problem on five client machines sharing 10 mbs into a server
Jul 07, 2017 | Microsoft Windows 7 Home Premium 64BIT...
Tally internal error forced to quit by tally user when open in work on education mode
Simply restart the server or pc. If you are in networking environment and working on client pc then unplg the netwrk cable from server and plug it again.
Aug 12, 2013 | Computers & Internet
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
I have a x64 Win 2008 print server that I share print queues . All my clients are x86 Win 7 and XP x86. I was told that I had to change name of driiver for it to work, why and how do I do that.
Logon to the print-server, and change the name of the "shared" resource.
If that does not work, change the name of the print-server (if you understand what effect that will have!).
Jun 14, 2011 | Office Equipment & Supplies
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at .
Mar 17, 2011 | HP Laserjet P4515x Printer
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
Tally support
maybe the licence for tally 9 is stored in an area of an application server on the network you dont have security access to? Do you have a system admin onsite to check this for you?
Feb 19, 2008 | Microsoft Windows Server 2003 Standard...
We give below a brief note on TallySynchronization and Data Migration Process: Synchronization refers to the process of Tally data being replicated between two or more locations. This enables a branch office to send its data to the head office over the Internet or a private network. Tally provides complete control over the frequency of replication. If the user is connected on a leased line, he can choose to replicate after every entry. If the user is not connected on a leased line, he can post his updates at specific intervals.
Synchronization is both ways - i.e., all data from the client company goes to the server and all data from the server company gets copied to the client company. After the synchronization has been set up, replicating data between the locations is a single click activity. Tally connects to the server, finds out the status of the last transfer (if any) and exchanges the incremental data that was entered after the last transfer. Tally also takes care of creating all mast! ers required to save the transaction on the target machine.
Jan 09, 2008 | Computers & Internet
Tally T2250 Matrix Printer Logo
1,249 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
