Question about Husqvarna Garden
Manual for Husqvarna rideon mower 18/48XP - Husqvarna Garden
  • pam101 Apr 17, 2009
    No this didn't work, I tried every model number I could find for a Husqvarna riding lawn mower and there wasn't one manual to be found on their site. I have spent an hour trying to find some kind of operating manual for my new Husqvarna YT16542 riding lawn mower, all I have is the Owner's manual which lists every part of the machine, but not basic operating instructions. All I wanted was to read the manual online and not have to go back to the store where I bought the machine. Not going to happen I guess.
4 Suggested Answers
  • 48 Answers
SOURCE: bent pushrod on inlet valve,husqvarna rideon mower
it is one of two problems - your engine uses a cam with a plastic gear - this gear has a tendency to move - it will probably need replacement . there is also a chance that the valve seat is coming loose (overhead valve ) which keeps the valve open - check the distance of the valve stems to make sure they are both out the same distance if they are not then when you put a new pushrod in and adjust it the valve will be pushed too far and hit the piston in turn bending the pushrod
Posted on Oct 17, 2008
kel1guy2002
  • 3740 Answers
SOURCE: Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
SOURCE: I could use a manual for a rideon mower I was given by a friend It's a
  • Well, what kind of mower?
Posted on Nov 22, 2011
Fit belt for product no 96011 0219 00
Bring your old belt to your local mower shop. They can match up a new one for you
Jan 25, 2015 | Husqvarna Garden
My tractor will not start, battery is good; I think I need a solenoid or starter for Model # YTH180 HUSQVARNA Lawn, Tractor
Hi there I had the same problem with my rideon mower I thought it was the solenoid as battery was new but I found that the 1 of the leads that go to the battery had worn onto the chasey making it not to start put some electrical tape if worn or replace the lead.
Oct 29, 2014 | Garden
Lawn mower won't engage forward or reverse "drive belt is not broken
If it's a JD rideon make sure you have pushed the lever back in all the way!
Apr 17, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Kelly
Aug 09, 2011 | Husqvarna Garden
Husqvarna LR130 burnt out starter
it has one but the way to fix it is to adjust the exahust valve thay should know that thats is how to fix that now the reason you cant find any thing on this is becous tecumseh is out of buisness thay have been out since 2008 i hope this helps you if not call me and ill help ya 918-7281822
Mar 06, 2010 | Husqvarna Garden
Belts coming off rideon 970
Hello maryswe:
>>This Problem is Usually Caused by a Bad Belt, Pulley or Belt Guard.
>>Check the Belt, if the Belt is Good, then Make Sure All the Belt Guards are Set to within 1/4" from the Belt.
>>If the Guards are Set Correctly, then Check for a Bent Pulley.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Husqvarna Garden
Garden Logo
236 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
